AVS › AVS Forum › Video Components › Home Theater Computers › Assembling HTPC in Origen S16V and S14V cases
Assembling HTPC in Origen S16V and S14V cases - Page 6
post #151 of 174
G'day Zygmunt,
Well I've confirmed that the IRTrans software is set to "3" in the brightness setting. It's really really dim. Every other VFD device in my tv cabinet is clearly visible from the couch. Bit of a shame really. Would have been nice to find out it was just set to a lower light level.
With regards to your other comments, obviously there's the potential that it might not fit, dimensions wise, but i'll measure it all very carefully this weekend. The VFD/IR hardware in the S16V takes up a lot of room, so I doubt that the depth of the lcd is going to pose a problem.
In regards to the value you mentioned, I can get a 7" usb monitor for US$80. Strikes me as a much better option than selling my S16V and buying an S16T? In Australia, the difference between these 2 cases is about US$350!
Cheers,
mumble
post #152 of 174
Originally Posted by mumble View Post
G'day Zygmunt,
Is your case under warranty? Ask your dealer for VFD replacement.
Cheers,
mumble
Best Regards
post #153 of 174
Best Regards
Unfortunately it's 16 months old, so out of warranty.
Zyg, have you had any experience removing the window at the front of the S16V? Is it something that just pops in and out?
Cheers, and thanks for all of your help.
Rhian
post #154 of 174
This is my first post, so Hello everyone.
After reading almost every thread on HTPC's in numerous forums I've just purchased an Origenae S16V-VFD310 from Perfect Home Theater website(glad they ship to Canada). I purchased the HM100 also since I don't plan on using the HDD cage initially.
I'm looking forward to building a Gaming HTPC. I'll Post pictures after completion. I'm a little meticulous about building my computers so this may take a while.
The components I'm looking at so far are an Intel i7 960 3.2 GHz, a WD VelociRaptor 600GB HDD for operations, a 2TB HDD for Storage, and a Radeon HD 5870 1GB Video Card. The rest is still undecided.
Any comments please weigh in. All comments (pro or con) welcome.
post #155 of 174
That's going to be one sweet build. That's the same case I plan on getting-hopefully when the go on sale (hint, hint). They sure are beautiful cases.
The length of the 5870 will definitely kill the HD cage (as I am sure you are already aware). Based on the spec's, it will probably leave you room for one more HD if you modify the cage.
Good luck with the build...
post #156 of 174
Zygmunt,
I'm looking to upgrade my mobo and CPU in my S14V. Will this RAM work?
http://www.newegg.com/Product/Produc...82E16820231193
post #157 of 174
I don't see any problem.
BTW it is good memory, I use this memory in my systems.
Regards
Zygmunt
post #158 of 174
I need some help with the VF210. I am trying to enable support with Windows 7 Media Center if possible. If this is not possible maybe just change the text. It has been displaying the same welcome screen since I bought the case over a year ago. I have already loaded the latest drivers/software for Windows 7 x64 (ir_trans_v09.10.09). It took me forever to figure out that Visual C++ Runtime 8.0 SP1 was actually Visual C++ 2005 edition. I think I have three different years of Visual C++ on my machine now
post #159 of 174
has anybody else had an issue with the 24pin adapter between the psu and mobo power connector? I spent about a half hour trying to connect the adapter to my main psu cable and noticed the adapter pins were actually pushing out of the housing. I had to cut the fan power wires and connector off the adapter and solder them to my psu power cable. That was annoying...
post #160 of 174
Hi Blk
I built several HTPCs with VFD210 and W7 (32 and 64 bit.)
Everything works fine.
What is important that you HAVE TO uninstall older version before installing new one.
You HAVE TO check MCE display driver. It should work.
If it doesn't work, e-mail me and I will send you a driver 09.05.10.
You can also go to IRTrans and download last drivers from them.
Best Regards
post #161 of 174
A new picture of my watercooled S16V HTPC/Gaming PC:
ASUS P6X58D Premium LGA 1366 Intel X58 Motherboard
Core i7 930 CPU
WD Raptor 300GB HDD
Koolance VID-NX295S VGA cooler
Koolance CPU-350 AC CPU cooler
Koolance INS-FM17N Coolant Flow Meter (replaces CPU fan)
6Gb OCZ gold DDR3 1600 memory
XFX 295GTX Graphics card ( HDD cage had to be removed to fit )
Corsair HX1000W 1000 watt modular PSU
http://i.imgur.com/bcEri.jpg
post #162 of 174
post #163 of 174
Hello all,
I am new here and I plan to buy an Origen S14V case and fill it with the following hardware:
- Intel DH67BL microATX motherboard
- Intel Core i3-2120T processor
- Kingston 2 x 2 Gb DDR3-1333
- Seasonic S12 Energy Plus SS-650HT PSU
Is there any incompatibility between the case and the motherboard ?
Will the default ventirad shipped with core i3-2120T fit in height into the S14V ?
Thank you in advance for your answers.
post #164 of 174
Originally Posted by pjalaber View Post
Hello all,
SATA connectors are UP so there is no conflict with cage.
No problem with this PSU. It is not too deep so no conflict with ODD.
You will be fine. There is total 117mm clerance for Mobo with CPU and HSF. Look here (if you didn't yet).
Regards
post #165 of 174
I'm looking for a few answers for my build with the S16T.
Will the Noctua NH-D14 Socket 2011 cooler fit in this case?
Also, I read it doesn't fit long video cards, I don't see the dimensions of the 2 Sapphire 6870's on NewEgg. Will it fit that card and still be able to use all the HDD bays?
Link to 6870's
Also, will this Sony Blu Ray Burner work?
Sony Blu Ray Burner
post #166 of 174
No way! Did you read this?:
http://perfecthometheater.com/techsu...ze_of_vide.htm
or this:?
http://perfecthometheater.com/techsu...nflict-OAE.htm
Link to 6870's
No. It is too long for S16* case.
Physical Specifications
Height 4.53"
Length 9.84"
Width Dual Slot
Sony Blu Ray Burner
Yes, unless you use very long PSU.
post #167 of 174
Height 4.53"
Length 9.84"
Width Dual Slot
What video card(s) would you recommend then?
I've found a 6870 that says its 238mm Long. The diagram you provided showed I had 245mm if I have all 3 HDD's in. Before I order this can you confirm it will fit?
http://pcsdesign.ca/Products/index.p...HD6870+1G+DDR5
post #168 of 174
Am I going to have issues with memory modules that are 47mm tall?
Is the CM GeminII S524 a good cooler choice? It looks like it should fit according to the link...
Is there a particular tower cooler that people use in the S16V? It seems like 130mm makes it impossible to fit a tower in there at all?
post #169 of 174
Hey guys, its been a long time. biggrin.gif Just upgraded my S16V with new internals and got rid of my water cooling setup:
ASUS P8Z77-V LE motherboard
Intel Core i5 3570K CPU
Coolermaster GeminII S524 CPU cooler
WD Raptor 300GB HDD
8Gb ADATA DDR3 1600 PC3-12800
BFG 295GTX Graphics card ( HDD cage had to be removed to fit )
post #170 of 174
Yes, I got to fit (see my recent post), but it also depends on your motherboard layout. Try to compare with the motherboard before buying. (Don't forget to measure clearance for the end of the CD/DVD drive.)
The ZALMAN CNPS9500A-LED also fits (make sure it includes the install kit for your socket)
There are also some low height, downward blowing Zalmans, like CNPS7000C-AlCu that might work.
The Coolmaster Vortex Plus should work.
post #171 of 174
Zygmunt,
I just visited your site and I am interested in the NEW S16V with USB 3.0/USB 2.0 ports in the front. HTPC aluminum chassis-S16V-VFD310 (Black) - HTPC-S16V-VFD310-B.
1. Can you confirm that this model number comes with USB 3.0/USB 2.0 ports in the front? Your picture still shows the Firewire port.
2. What remote does the new S16V come with, RC197 or iMon? I assume iMon since its a 310 VFD/IR inside.
3. Your website says "out of stock" , how long until back in stock?
4. Can I buy just the new front media bay with USB 3.0 separately and add it to my system? Will it fit in the older S16V with IR210 and Media bay with firewire?
post #172 of 174
Originally Posted by kmd1970 View Post
Zygmunt,
Confirmed.. I received pictures from Origen last week and replaced old ones. Please refresh pages.
Correct.
. Origen should ship them in the week, so ~6 weeks from now.
Yes and Yes. I should receive these parts with cargo.
post #173 of 174
Hi, I went to your website and I can only see this picture below. I assume the blue port is USB 3.0 and the other is USB 2.0?
Also, my current S16V case has 2 horizontal USB and 1 firewire port cutout. If the new USB 3.0 media bay doesn't have the same cutout areas, the second USB 2.0 port will not be useable.
post #174 of 174
Correct.
If you want 3.0 in front, you have to replace PCB and aluminum panel. I will have such sets next month. Maybe even this months. I am waiting for info from Origen.
Regards
