Originally Posted by
peaces
Hi Zygmunt
Got the IRTransView_64.dll!!!! It is working.
That's great!
Great box, and thanks for the help. But since you are the "expert" here.
No, I am not an expert in computers.
After PCAlchemy closed their doors forever, I felt obligated to cary all parts for cases I sell and learn as much as possible about OrigenAE cases and built in components to be able to help my clients. I didn't build enough different PC configurations to be "an expert" in computers.
I got just one problem. The Gigabyte NVidia 9400 MoBo, (saw it in your selection for the "prebuilt systems" good idea by the way.)
Anyway, I am using the NVidia sound and only one HDMI cable (that is why I am using the NVidia instead of the RealTek). It pops a lot whenever a new application starts to send sound. And ussually pops when the program stops (or maybe it is the standard Vista sound taking over). Anyway have tried all the Vista sound settings for CD CD quality DVD... All the different bits and Mhz... Still the pop.
Any Ideas, or do you just use the RealTek, and you do not have a problem with this sound?
I don't have such problem with my systems. (Gigabyte GA-MA78GPM-DS2H and Gigabyte GA-P35-DS3L)
Thanks for all your help.
Basicly the remaining problems I have I think a Asus Xonar 1.3 will fix. Good sound, WILL change the pc HDMI output from a PC to a standard vidio HDMI.... (like a bluray or satelite - the PC hdmi forces me to set the LCD input to be a PC to scale properly. All other HDMI device I can select a lot of different types of Input on the LCD and they all work. Only the PC HDMI requires a PC on the TV to scale correctly).
