AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Pioneer 9G Kuro Settings/Issues Thread
post #1 of 10674
****UNDER NO CIRCUMSTANCE SHOULD THESE SETTINGS BE USED WITH ANY OTHER SOURCE MATERIAL BEYOND THE PANEL AGING DVD OR THUMBDRIVE FILES****
Recommended 150 Hour (150 hours non-stop) Panel Aging settings for Pioneer 5020FD/6020FD (ONLY to be used with Evangelo2's DVD or Thumbdrive Files!!!!!!!!)
*****Note: This procedure is designed to be performed only during the first 150 hours of the display's lifespan. This procedure is designed to equally and evenly age all pixels and ensure the reference settings listed below provide maximum satisfaction. This procedure is NOT designed nor recommended to be used as Image Retention and/or Burn-in prevention. If a setting is not listed in the settings below, please leave it at its default value*****
Picture:
AV Selection: Sport
Contrast: 50
Brightness:0
Color: +20
Tint: 0
Sharpness: 0
Pure Cinema
Film Mode: Off
Text Optimization: Off
Screen Size: Full
Power Save Mode: Off
Orbiter: Mode 1
Recommended 150 Hour (150 hours non-stop) Panel Aging settings for Pioneer 111FD/151FD (ONLY to be used with Evangelo2's DVD or Thumbdrive Files!!!!!!!!)
*****Note: This procedure is designed to be performed only during the first 150 hours of the display's lifespan. This procedure is designed to equally and evenly age all pixels and ensure the reference settings listed below provide maximum satisfaction. This procedure is NOT designed nor recommended to be used as Image Retention and/or Burn-in prevention. If a setting is not listed in the settings below, please leave it at its default value.*****
Picture:
AV Selection: Sport
Contrast: 50
Brightness: 0
Color: +20
Tint: 0
Sharpness: 0
Pro Adjust
Pure Cinema
Film Mode: Off
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 2
Gamma: 2
Color Detail:
Color Temp: High
CTI: Off
Color Management
R 0
Y 0
G 0
C 0
B 0
M 0
Color Space: 2
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full
Power Save Mode: Standard
Orbiter: Mode 1
Recommended 150 (150 hours non-stop) Hour Panel Aging settings for Pioneer 500M/600M (ONLY to be used with Evangelo2's DVD!!!!!!!!)
*****Note: This procedure is designed to be performed only during the first 150 hours of the display's lifespan. This procedure is designed to equally and evenly age all pixels and ensure the reference settings listed below provide maximum satisfaction. This procedure is NOT designed nor recommended to be used as Image Retention and/or Burn-in prevention. Also, if a setting is not listed in the settings below, please leave it at its default value.*****
Picture:
AV Selection: Sport
Contrast: 50
Brightness: 0
Color: +50
Tint: 0
Sharpness: 0
Pro Adjust
Pure Cinema
Film Mode: Off
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 1
Gamma: 4
Color Detail:
Color Temp: High
CTI: Off
Color Management
R 0
Y 0
G 0
C 0
B 0
M 0
Color Space: 1
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full 1
Orbiter: Off
Drive Mode: 1
post #2 of 10674
Pioneer 5020FD/6020FD Non-Service Menu Adjusted Reference Settings (Can be used with (after) or without the recommended break-in procedure)
Picture:
AV Selection: Movie
Contrast: 38
Brightness: -1
Color: -4
Tint: R1
Sharpness: -15
Pure Cinema
Film Mode: Advance
Orbiter: Mode 2
Pioneer 5020FD Service Menu Adjusted Reference Settings (ControlCAL is required for these settings. ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
Picture:
AV Selection: Movie
Contrast: 39
Brightness: 0
Color: +1
Tint: R1
Sharpness: -15
Pure Cinema
Film Mode: Standard
Orbiter: Mode 2
Service Menu RGB Offsets
R-High: -13
G-High: 0
B-High: +49
R-Low: 0
G-Low: 0
B-Low: 0
Pioneer 6020FD Service Menu Adjusted Reference Settings (ControlCAL is required for these settings. ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
Picture:
AV Selection: Movie
Contrast: 40
Brightness: 0
Color: +1
Tint: R1
Sharpness: -15
Pure Cinema
Film Mode: Standard
Orbiter: Mode 2
R-High: +25
G-High: -5
B-High: +51
R-Low: 0
G-Low: 0
B-Low: 0
Service Menu Adjusted Calibration Reports:
Pioneer PDP-6020FD Post Calibration Report (Movie Mode).pdf 176.9541015625k . file
Pioneer PDP-5020FD Post Calibration Report (Movie Mode).pdf 175.6435546875k . file
post #3 of 10674
Pioneer Elite 111FD Pure Mode Reference Settings (ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
Picture:
AV Selection: Pure
Contrast: 37
Brightness: 0
Color: +3
Tint: 0
Sharpness: -15
Pro Adjust
Pure Cinema
Film Mode: Advance
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 1
Gamma: 2
Color Detail:
Color Temp: Manual
R High -1
G High 0
B High +4
R Low -1
G Low +1
B Low 0
CTI: Off
Color Management
R -2
Y +2
G -1
C -1
B +1
M -1
Color Space: 2
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full
Orbiter: Mode 2
Calibration Report:
Pioneer Elite PRO-111FD Post Calibration Report (Pure Mode).pdf 177.28515625k . file
post #4 of 10674
Pioneer Elite 111FD ISF-Day Reference Settings (2008 111FDs Only. ControlCAL is required for these settings. ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
Picture Settings:
AV Selection: ISF-Day
Contrast: 36
Brightness: 0
Color: +3
Tint: 0
Sharpness: -15
Pure Cinema: 2 (Advance)
Black Level: 0 (Off)
CTI: 0 (Off)
Color Space: 2
Color Temp: 6 (Manual)
ACL: 0 (Off)
3DYC: 2 (Mid)
I-P Mode: 2
Text Optimization: 0 (Off)
Intelligent Mode: 0 (Off)
DRE Picture: 0 (Off)
Enhancer Mode: 1
Block NR: 0 (Off)
3DNR: 0 (Off)
Field NR: 0 (Off)
Mosquito NR: 0 (Off)
Orbiter: Mode 2
RGB Controls
R High: -2
G High: 0
B High: +3
R Low: -1
G Low: 0
B Low: 0
Color Management
R: -1
Y: +1
G: 0
C: -1
B: +1
M: -1
Gamma
10%R -1
10%G -1
10%B -1
20%R -1
20%G -1
20%B -1
30%R -1
30%G -1
30%B -1
40%R -1
40%G -1
40%B -1
50%R -1
50%G -1
50%B -1
60%R -1
60%G -1
60%B -1
70%R -1
70%G -1
70%B -1
80%R -1
80%G -1
80%B -1
90%R -1
90%G -1
90%B -1
Calibration Report:
Pioneer Elite PRO-111FD Post Calibration Report (ISF-Day).pdf 175.9970703125k . file
post #5 of 10674
Pioneer Elite 111FD ISF-Night Reference Settings (2008 111FDs Only. ControlCAL is required for these settings. ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
Picture Settings:
AV Selection: ISF-Night
Contrast: 18
Brightness: 0
Color: +3
Tint: 0
Sharpness: -15
CTI: 0 (Off)
Color Space: 2
ACL: 0 (Off)
3DYC: 2 (Mid)
I-P Mode: 2
Enhancer Mode: 1
Block NR: 0 (Off)
3DNR: 0 (Off)
Field NR: 0 (Off)
Orbiter: Mode 2
RGB Controls
R High: -3
G High: 0
B High: +3
R Low: 0
G Low: 0
B Low: 0
Color Management
R: +1
Y: +1
G: +1
C: 0
B: +2
M:-2
Gamma
10%R -1
10%G -1
10%B -1
20%R -1
20%G -1
20%B -1
30%R -1
30%G -1
30%B -1
40%R -1
40%G -1
40%B -1
50%R -1
50%G -1
50%B -1
60%R -1
60%G -1
60%B -1
70%R -1
70%G -1
70%B -1
80%R -1
80%G -1
80%B -1
90%R -1
90%G -1
90%B -1
Calibration Report:
Pioneer Elite PRO-111FD Post Calibration Report (ISF-Night).pdf 177.4931640625k . file
post #6 of 10674
Pioneer Elite 151FD Pure Mode Reference Settings (2008 "Plus Green" 151FDs Only. ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
Picture:
AV Selection: Pure
Contrast: 38
Brightness: 0
Color: +3
Tint: 0
Sharpness: -15
Pro Adjust
Pure Cinema
Film Mode: Advance
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 1
Gamma: 2
Color Detail:
Color Temp: Manual
R High +2
G High -1
B High +3
R Low -1
G Low +1
B Low 0
CTI: Off
Color Management
R 0
Y +1
G +1
C -1
B +2
M -2
Color Space: 2
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full
Orbiter: Mode 2
Calibration Report:
Pioneer Elite PRO-151FD Post Calibration Report (Pure Mode).pdf 181.2099609375k . file
post #7 of 10674
Pioneer Elite 151FD ISF-Day Reference Settings (2008 "Plus Green" 151FDs Only. ControlCAL is required for these settings. ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
Picture Settings:
Contrast: 38
Brightness: 0
Color: +3
Tint: 0
Sharpness: -15
CTI: 0 (Off)
Color Space: 2
ACL: 0 (Off)
3DYC: 2 (Mid)
I-P Mode: 2
Enhancer Mode: 1
Block NR: 0 (Off)
3DNR: 0 (Off)
Field NR: 0 (Off)
Orbiter: Mode 2
RGB Controls
R High: +3
G High: -1
B High: +4
R Low: -1
G Low: +1
B Low: 0
Color Management
R: 0
Y: +2
G: +1
C: -2
B: +2
M: -1
Gamma
10%R -1
10%G -1
10%B -1
20%R -1
20%G -1
20%B -1
30%R -1
30%G -1
30%B -1
40%R -1
40%G -1
40%B -1
50%R -1
50%G -1
50%B -1
60%R -1
60%G -1
60%B -1
70%R -1
70%G -1
70%B -1
80%R -1
80%G -1
80%B -1
90%R -1
90%G -1
90%B -1
Calibration Report:
Pioneer Elite PRO-151FD Post Calibration Report (ISF-Day).pdf 177.8916015625k . file
post #8 of 10674
Pioneer Elite 151FD ISF-Night Reference Settings (2008 "Plus Green" 151FDs Only. ControlCAL is required for these settings. ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
Picture Settings:
Contrast: 22
Brightness: 0
Color: +3
Tint: 0
Sharpness: -15
CTI: 0 (Off)
Color Space: 2
ACL: 0 (Off)
3DYC: 2 (Mid)
I-P Mode: 2
Enhancer Mode: 1
Block NR: 0 (Off)
3DNR: 0 (Off)
Field NR: 0 (Off)
Orbiter: Mode 2
RGB Controls
R High: +3
G High: -1
B High: +4
R Low: -1
G Low: +1
B Low: 0
Color Management
R: 0
Y: +2
G: +1
C: -2
B: +2
M: -2
Gamma
10%R 0
10%G 0
10%B 0
20%R 0
20%G 0
20%B 0
30%R 0
30%G 0
30%B 0
40%R 0
40%G 0
40%B 0
50%R 0
50%G 0
50%B 0
60%R 0
60%G 0
60%B 0
70%R 0
70%G 0
70%B 0
80%R 0
80%G 0
80%B 0
90%R 0
90%G 0
90%B 0
Calibration Report:
Pioneer Elite PRO-151FD Post Calibration Report (ISF-Night).pdf 178.974609375k . file
post #9 of 10674
Pioneer KRP-500M Pure Mode Reference Settings (ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
Picture:
AV Selection: Pure
Contrast: 38
Brightness: +1
Color: +2
Tint: 0
Sharpness: -15
Pro Adjust
Pure Cinema
Film Mode: Advance
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 1
Gamma: 2
Color Detail:
Color Temp: Manual
R High -4
G High 0
B High +3
R Low -1
G Low +1
B Low +1
CTI: Off
Color Management
R 0
Y +2
G 0
C 0
B 0
M 0
Color Space: 2
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full 1
Orbiter: Mode 1
Drive Mode: 1
Calibration Report:
Pioneer KRP-500M Post Calibration (Pure Mode).pdf 195.673828125k . file
post #10 of 10674
Thank you D-Nice!
post #11 of 10674
Originally Posted by D-Nice View Post
Pioneer 111FD/111FD Reference Settings [...]
Hi D-Nice,
It's great to see the settings and issues thread up and running; thanks much for starting it and posting your settings on it. I look forward to everyone's reports.
I'm guessing that the text I quoted above contains a typo, yes? Did you mean to say "111FD/151FD Reference Settings" (or am I missing something)?
Yours,
David
post #12 of 10674
D-nice, I thought Mode 2 was for dot by dot. Mode 1 was for full, etc. Did I miss something?
post #13 of 10674
Thanks D-Nice.
I am confused by what you mean by:
(Break-in DVD/Thumbdrive Owners ONLY!!!!!!! ONLY use these settings after the 150 hour break-in period!!!!!!!!
May I use these settiings if I used the DVD to Break-in my 151? I used Evangelo2's Break-in DVD with the settings recommended for the 8G plasmas.
Sorry if this is a dumb question.
post #14 of 10674
Originally Posted by davidjschenk View Post
Hi D-Nice,
Yours,
David
Yep, and corrected
post #15 of 10674
subscribed! btw wasnt their mutiple settings threads on 9g pioneers or am i just seeing too many threads?
post #16 of 10674
Originally Posted by maphiker View Post
Thanks D-Nice.
It means that these settings are only for owners who did the recommended break-in proceedure. If you do not do that proceedure, do not use these settings as they will not look correct.
post #17 of 10674
Mode 2 works with all stretch modes....just uses a different orbiter pattern.
post #18 of 10674
Are there any D65 settings you could provide? Thanks so much for this.
post #19 of 10674
I only saw the non-Elite settings thread.
post #20 of 10674
There are the "Reference" settings
post #21 of 10674
Can someone compare what dot-by-dot means to full?
post #22 of 10674
Ah, so the reference settings are ~D65? Then the ones actually listed specifically as D55 are D55, and then you're going to provide some D75 for sports/blue junkies?
Awesome. How far off from dead-on true D65 do you think those reference settings are? Is it possible to get a true D65 gray scale with just user adjustments? If so, I'm tickled.
post #23 of 10674
Yes
....and then you're going to provide some D75 for sports/blue junkies?
Yes
Color temp was pretty much flat from 20-100IRE. DeltaE averaged 2 from 20-30IRE and 0.7 from 40-100IRE. It doesn't really get any better than that
Look up
post #24 of 10674
Thank you^10th D-Nice. Not worthy :bow:
Gonna go run the disc on these settings now.
Thanks again to all.
post #25 of 10674
Wow, D-Nice, the settings before and after break-in REALLY changed!
I'll have to check out those settings and see how they work on my 151!
Thanks again.
Oh and... Subscribed!!
post #26 of 10674
Thanks D. Can't wait unitl Fri. when my 151 is scheduled to arrive. Then the fun begins.
post #27 of 10674
if doing the break-in on the 111 with periods of watching full screen in between, do you suggest reference settings for non-break in users or reference settings for after break in for those periods?
post #28 of 10674
These breakin settings are a bit different than what was posted a couple of weeks ago. I ran my breakin on the old settings for 150 hours. Should I run for a few hours at these settings? If so, for how much longer?
post #29 of 10674
Thank you, Sir.
post #30 of 10674
To be honest, I don't really know. My best guess would be to use the break-in settings and the settings labeled "Non-Break-in DVD/Thumbdrive Owners ONLY!!!!!!!".
The settings labeled "Break-in DVD/Thumbdrive Owners ONLY!!!!!!! ONLY use these settings after the 150 hour break-in period!!!!!!!!!
are exclusive to those who choose to follow the break-in proceedure to the "T".
