****UNDER NO CIRCUMSTANCE SHOULD THESE SETTINGS BE USED WITH ANY OTHER SOURCE MATERIAL BEYOND THE PANEL AGING DVD OR THUMBDRIVE FILES****
Recommended 150 Hour (150 hours non-stop) Panel Aging settings for Pioneer 5020FD/6020FD (ONLY to be used with Evangelo2's DVD or Thumbdrive Files!!!!!!!!)
*****Note: This procedure is designed to be performed only during the first 150 hours of the display's lifespan. This procedure is designed to equally and evenly age all pixels and ensure the reference settings listed below provide maximum satisfaction. This procedure is NOT designed nor recommended to be used as Image Retention and/or Burn-in prevention. If a setting is not listed in the settings below, please leave it at its default value*****
Picture:
AV Selection: Sport
Contrast: 50
Brightness:0
Color: +20
Tint: 0
Sharpness: 0
Pure Cinema
Film Mode: Off
Text Optimization: Off
Screen Size: Full
Power Save Mode: Off
Orbiter: Mode 1
Recommended 150 Hour (150 hours non-stop) Panel Aging settings for Pioneer 111FD/151FD (ONLY to be used with Evangelo2's DVD or Thumbdrive Files!!!!!!!!)
*****Note: This procedure is designed to be performed only during the first 150 hours of the display's lifespan. This procedure is designed to equally and evenly age all pixels and ensure the reference settings listed below provide maximum satisfaction. This procedure is NOT designed nor recommended to be used as Image Retention and/or Burn-in prevention. If a setting is not listed in the settings below, please leave it at its default value.*****
Picture:
AV Selection: Sport
Contrast: 50
Brightness: 0
Color: +20
Tint: 0
Sharpness: 0
Pro Adjust
Pure Cinema
Film Mode: Off
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 2
Gamma: 2
Color Detail:
Color Temp: High
CTI: Off
Color Management
R 0
Y 0
G 0
C 0
B 0
M 0
Color Space: 2
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full
Power Save Mode: Standard
Orbiter: Mode 1
Recommended 150 (150 hours non-stop) Hour Panel Aging settings for Pioneer 500M/600M (ONLY to be used with Evangelo2's DVD!!!!!!!!)
*****Note: This procedure is designed to be performed only during the first 150 hours of the display's lifespan. This procedure is designed to equally and evenly age all pixels and ensure the reference settings listed below provide maximum satisfaction. This procedure is NOT designed nor recommended to be used as Image Retention and/or Burn-in prevention. Also, if a setting is not listed in the settings below, please leave it at its default value.*****
Picture:
AV Selection: Sport
Contrast: 50
Brightness: 0
Color: +50
Tint: 0
Sharpness: 0
Pro Adjust
Pure Cinema
Film Mode: Off
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 1
Gamma: 4
Color Detail:
Color Temp: High
CTI: Off
Color Management
R 0
Y 0
G 0
C 0
B 0
M 0
Color Space: 1
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full 1
Orbiter: Off
Drive Mode: 1
Picture:
AV Selection: Sport
Contrast: 50
Brightness:0
Color: +20
Tint: 0
Sharpness: 0
Pure Cinema
Film Mode: Off
Screen Size: Full
Orbiter: Mode 1
Picture:
AV Selection: Sport
Contrast: 50
Brightness: 0
Color: +20
Tint: 0
Sharpness: 0
Pro Adjust
Pure Cinema
Film Mode: Off
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 2
Gamma: 2
Color Detail:
Color Temp: High
CTI: Off
Color Management
R 0
Y 0
G 0
C 0
B 0
M 0
Color Space: 2
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full
Orbiter: Mode 1
Picture:
AV Selection: Sport
Contrast: 50
Brightness: 0
Color: +50
Tint: 0
Sharpness: 0
Pro Adjust
Pure Cinema
Film Mode: Off
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 1
Gamma: 4
Color Detail:
Color Temp: High
CTI: Off
Color Management
R 0
Y 0
G 0
C 0
B 0
M 0
Color Space: 1
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full 1
Orbiter: Off
Drive Mode: 1
