AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Pioneer 9G Kuro Settings/Issues Thread
The Official Pioneer 9G Kuro Settings/Issues Thread - Page 69
post #2041 of 10658
Originally Posted by D-Nice View Post
RGB offsets have been posted in Post #2 of this thread. Please be aware the ControlCAL is required to use these settings.
As always, enjoy
post #2042 of 10658
Pioneer 5020FD Service Menu Adjusted Reference Settings (ControlCAL is required for these settings. ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
Picture:
AV Selection: Movie
Contrast: 39
Brightness: 0
Color: +1
Tint: R1
Sharpness: -15
Pure Cinema
Film Mode: Standard
Text Optimization: Off
Power Save Mode: Off
Orbiter: Mode 2
Service Menu RGB Offsets
R-High: -13
G-High: 0
B-High: +49
R-Low: 0
G-Low: 0
B-Low: 0
are the numbers from the default number or from 500?
post #2043 of 10658
As always, enjoy
I have a few questions that are probably shared with others...
1. On the controlcal site it says to put the PC mode to off while making sm adjustments. If it is put in standard mode after calibration will the settings hold?
2. How many samples are your rgb offsets based on ? Are these panels similar enough that they should be good for most sets?
3. I was surprised that there was a difference for 5020 and 6020, what do you think accounts for this?
post #2044 of 10658
Has anyone else had their tv freeze while moving around in the menu? After freezing the tv reboots itself and says please wait tv starting up. Is this normal? Was the memory bank all filled up ?
post #2045 of 10658
Originally Posted by Rabid1 View Post
I'm having issues getting ControlCal to turn my 6020 on.
I'm using a KeySpan adapter, and it is correctly installed on my 64 bit Vista machine.
The baud rate is set to the default 9600. When I load ControlCal, the green light on the KeySpan goes from flashing to steady.
ControlCal gives no communication errors. All of the ControlCal's settings are set to default.
I click the power on button, it shows the command was sent, but nothing happens, even after over a minute.
Am I missing something?
Rick
What is the configuration of your serial cable? It needs to be "straight through" (required pins are #2, 3 & 5 (Rx, Tx and Ground). Most Female-Female serial cables I have seen are made to connect one PC to another and are "Null Modem" serial cables, where pins 2 & 3 are inverted from one end to the other. This type of cable will not work to connect a PC to a Pioneer serial port.
Dan
post #2046 of 10658
These are offsets. Whatever your settings are, you adjust them per the offsets.
post #2047 of 10658
Yes.
Enough
Yes
This has been discussed numerous times. You will have to research this thread to find out why.
post #2048 of 10658
the confusion for me on this is that, my default for R-High is 515, and ControlCal starts off everything at 500. so is the -13 you posted taken from a default of 515 or 500?
post #2049 of 10658
If you press the refresh button, it will retrieve your current values. The -13 is from your default value. Didn't we go over this about a month ago?
post #2050 of 10658
Originally Posted by gamelover360 View Post
You use Controlcal to turn on the tv.....their is a power on button right their in the interface. You are not using your tv remote.
Correct. That's why I said I can't get ControlCal to turn on my TV.
post #2051 of 10658
Dan
That would be it! Thanks my man.
post #2052 of 10658
About a week or two ago So how big is the range for RGB offsets (+49!!!). Does this mean it "could" be controlled to be more accurate than the elites (without entering controlcal). Why are there two different settings for RGB offsets, but not the non-SM reference settings on the 5020/6020.
Edit below: That's true. 0-999... Sounds like some people will be doing something stupid on their displays eventually.
post #2053 of 10658
0-999
No
Can you make any real adjustments in the regular user menu of the non-Elites
There is only so much you can do without hitting the SM.
post #2054 of 10658
I have a question about the break in procedure. Is it better to use the thumbdrive files or the dvd image? I started using the thumbdrive files but wasn't sure about the settings for the slideshow. I didn't know how long to set the interval to and I noticed that in between slides the screen goes black. I didn't know if this was ok and supposed to happen so I tried using the dvd image. I noticed with the dvd that the pictures are up there a lot longer and it seems like it has some different colors (more shades I think...but the screen is white a lot more often then when using the thumbdrive files and going straight through the images). I had assumed the dvd image and thumbdrive files were exactly the same. Can someone please let me know if there is a difference between the two and which I should use or what my settings should be. Thank you!
P.S. Sorry I kind of rambled lol...hopefully you understood what I was saying
post #2055 of 10658
The settings you should be using with either the DVD or the thumb drive files is the #1 post on this thread. I'm currently in the process of breaking in my Pro-111FD so I'm in the same boat as you are since I too have noticed that the DVD and thumb drive files are a bit different. I'll look forward to someone who's more knowledgeable answering that part of your question for both of us!
post #2056 of 10658
It doesn't matter which one you use, and the settings are the same for both.
post #2057 of 10658
Thanks much. I appreciate your input.
post #2058 of 10658
D-Nice
I'm very happy to report back that (after I got the right cable) I was able to apply your offsets with no difficulty. I went back into the SM and confirmed the settings were saved.
The key is to actually follow your instructions and not get ahead of yourself.
I'm even happier to report the significant improvement in my picture! It now seems so natural compared to the factory settings.
I know you don't accept payment for the settings you provide, but if you would PM me with your favorite charity I will make a donation to it.
I would encourage all of you 5020 & 6020 owners that are considering this, to go ahead and purchase ControCal and take the plunge. It's not expensive, and it's not difficult to use.
D, if you ever travel to God's Country (Bend, OR) I'm sure I can hook you up with two or three (maybe more) jobs. Be forewarned though, once you get here, you won't want to leave!
Thanks again!
Rick
post #2059 of 10658
Thanks for the kind words. No payment is neccessary....all I ask is that you help others whenever you can
D-Nice
Thanks again!
Rick
post #2060 of 10658
Ok gammers, I've created some settings for you guys (111FD owners only). Enjoy
Pioneer Elite 111FD Gamer Settings (ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
Picture:
AV Selection: Game
Contrast: 38
Brightness: 0
Color: -1
Tint: 0
Sharpness: -15
Pro Adjust
Pure Cinema
Film Mode: Off
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 2
Gamma: 2
Color Detail:
Color Temp: Manual
R High +5
G High 0
B High -14
R Low 0
G Low +1
B Low +1
CTI: Off
Color Management
R -2
Y +2
G -1
C -1
B +1
M +1
Color Space: 1
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full
Orbiter: Mode 2
Calibration Report:
PRO-111FD_PostCalibration(GameMode).pdf 179.0224609375k . file
post #2061 of 10658
As always, enjoy
Thanks D-Nice. I was successful making the changes you recommended to my 5020. This was my first attempt and I merely made the RGB offsets with out the use of a meter. I will probably buy one down the road. But the offsets alone do a nice job improving the picture, what I notice the most is the whites are brighter without losing detail. Movie mode no longer has that brownish/yellow cast.
This made me wonder what others had for their original factory settings, here are mine:
original after changes
R-H 523 510
G-H 522 522
B-H 500 549
All lows at 500
post #2062 of 10658
I have a 6020 on the way from Amazon. Are there any calibrators in the Miami Florida area?
post #2063 of 10658
Picture:
AV Selection: Game
Contrast: 38
Brightness: 0
Color: -1
Tint: 0
Sharpness: -15
Pro Adjust
Pure Cinema
Film Mode: Off
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 2
Gamma: 2
Color Detail:
Color Temp: Manual
R High +5
G High 0
B High -14
R Low 0
G Low +1
B Low +1
CTI: Off
Color Management
R -2
Y +2
G -1
C -1
B +1
M +1
Color Space: 1
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full
Orbiter: Mode 2
Calibration Report:
I'm praying that this means 151 Game mode is coming soon
post #2064 of 10658
So here's an update for all of you who know about my defective 151 panel. John Marty at Axxis sent me a new 151 when my first 151 blew a Scan IC the very first day. Anyways, I live in north Idaho, near Spokane, WA and there really aren't a lot of Pioneer Techs in the area. Anyways, Pioneer made some arrangements for the defective panel to be picked up and transported to the nearest repair shop in my area (they usually wouldn't have done this, and I wish they wouldn't have, because then I would have gotten a brand new one back from Pioneer).
Anyways, I called the repair shop today, since they haven't called me yet and they picked up the defective one this Wednesday. They told me it's been fixed and works like new again (hope fully better than new).
Again, I'm thankful John sent me a new panel, otherwise, I would have gone 3 full weeks without a TVSo I asked John what he would like me to do with the first new 151 and he said he will have his freight company come pick it up...or he would sell it to me for a very good deal. I don't want to post the price, but I wanted to get your ideas on this. I've never had two TV's in my house and I don't even need them, but I may be able to sell it and make some money. Any thoughts?
Josh
post #2065 of 10658
If you can sell it locally for a good price I would. Just dont try to ship it
post #2066 of 10658
Two 151's in your home!?! If the price is right, put them side by side, AKA, keep em both!!
post #2067 of 10658
+1
If it's too much trouble to find a local buyer, just let John take care of it.
post #2068 of 10658
Yeah, I think I may try this option.
This would be insane! I could hook up my computer and run them like dual monitors. Too bad my wife would/will never understand.
+1
It will probably come down to this, but it would be nice to sell locally and make a little bit of money. Plus it would save John the expense of shipping it.
I still can't believe Pioneer has no problem with letting me go 3 weeks without a TV (they don't know John overnighted my a new one). It must just be my area, and that there aren't many repair shops around.
post #2069 of 10658
Look at it from their perspective- the sale has already been made, they got their money out of you. What do they care how long you wait? So as it stands right now, John has footed the cost of the second TV?
post #2070 of 10658
Yeah as far as I know, John picked up all costs involved on the second Kuro 151 that was shipped to me. Like he said, one way or another, he did get me a NEW panel. I really hope his marketing rep took/takes care of him on this defective panel.
While I believe what you're saying, I'm still saddened that this is the approach that a lot of companies take...they just don't seem to value the client as much today and don't really look at the future business; barely even the present, but most of all they look at the past business and want their money now.
I'm very fortunate that these sponsors here at AVSF take care of the consumer and understand the importance of referrals and the value of their name.
Josh
