AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Pioneer 9G Kuro Settings/Issues Thread
The Official Pioneer 9G Kuro Settings/Issues Thread - Page 18
post #511 of 10646
Silly question, but what menu do I find these settings under?
Screen Size: Full
Power Save Mode: Off
Orbiter: Mode 1
post #512 of 10646
Screen size: Full - remote screen size button is easiest
power save mode: Off - power controls
orbiter: Mode 1 - options choice
post #513 of 10646
Hoping someone can help me with this.
I have a new 6020, and I have had a 5050 before so I am somewhat familiar with Pioneer. I set it to the reference setting at the beginning of the thread - it is new so has not had a break in yet.
I also have a Panasonic PZ85U with Tom Huffman's settings:
Cinema Mode, Pic 80, Bright 42, Color 35, Tint -2, Sharp 0, Color Temp warm, and Black Level light.
These two sets using the same cable box hdmi HD output don't look at all the same. Are my colors and brightness set way too high on the Panny because the 6020 looks very low color with very little flesh tones on any people?
Hopefully someone can help out a newb.
post #514 of 10646
post #515 of 10646
Question about D-Nice's ref settings vs Ultimate AV settings. Both were calibrated to 6500K, but when you compare the settings, they appear a lot different. Are individual sets that different, and/or does your viewing environment make that much of a difference? Or are they just calibrating to 6500K by two different routes to get to the same goal (i.e. adjust main color and tint settings one way, so the color detail/temp or Color Management settings have to be set a certain way to get to 6500K)
Here are the big differences:
Color: D=+2; UltAv = +9 (that seems like a big diff)
Tint: D = 0, UltAV = G4
R High: D = +1, UltAv = -6
B High: D = +4, UltAv = 0
Color Management: D = -2, +1, -4, -2, 0, -1 for the six; UltAV = all 0s
On anyone's specific set, if they were to implement either settings, will they get the same picture?
post #516 of 10646
No, D-Nice's settings are probably much better (as they are more, but not close to exact, in accordance with other reference settings I know of), but ULTav obviously didn't need to touch the CMS (due to CS2 accuracy)
post #517 of 10646
For those of you that like performance (like i do for DTV) - here are my current settings for Performance on my 151 - i used an I1-Pro to calibrate it to 6500k.
let me know how you like it - this is a work in progress but gives the picture a lot of punch
Picture:
AV Selection: Performance
Contrast: 31
Brightness: 0
Color: -5 (DTV) +1 (Blu-Ray)
Tint: 0
Sharpness: -13
Pro Adjust
Pure Cinema
Film Mode: Standard (DTV) Advanced (Blu-Ray)
Text Optimization: On
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 1
Gamma: 2
Color Detail:
Color Temp: Manual
R High +3
G High 0
B High +6
R Low -1
G Low 0
B Low 0
CTI: Off
Color Management
R 0
Y +1
G +1
C 0
B 0
M 0
Color Space: 2
Noise Reduction:
3DNR: Low
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: dot
Orbiter: Mode 2
post #518 of 10646
Looks great on my 151. If you have a 151, give these settings a try. I was pleasantly surprised!
post #519 of 10646
here are my setting for a European 5090H after 50 hrs of the breakin dvd.
after turning off ALL Enhancers in Movie mode:
Kon = 38
Bri =+1
Color = +3
CMS = no changes but use Color Space 2
Red-High = -5
Amazing little needed changing.
I'm running gamma at slightly less then 2.2. If kontrast is set to 39 and briteness to 0 i get a nice 2.2 gamma.
I'll try and tweak with CMS afdter 150 Hrs.
post #520 of 10646
d-nice:
question - when you do your calibration do you it as follows:
brightness
contrast
grey scale
color
tint
cms
then, do you go back to do the grey scale again becaue you changed the cms or do you stop.
thank you
post #521 of 10646
Contrast
Brightness
Grayscale
CMS
Re-check Grayscale
Re-check CMS
Color
I don't mess with the tint control.
Originally Posted by ikeb View Post
d-nice:
brightness
contrast
grey scale
color
tint
cms
thank you
post #522 of 10646
Nice You are going to have to redo everything after 150 hours
Kon = 38
Bri =+1
Color = +3
Red-High = -5
post #523 of 10646
I know. I just couldn't wait to play with the measuring equipment
Pioneer techie has offered a panel switch after they saw how badly mine is blotched. Called it borderline. So I'll have to rerun breakin.
post #524 of 10646
Pardon my ignorance. I have a PRO-151FD on its way to the house. Does this mean I need to plug the thumb drive in and let the plasma run continuously for about a week (150 hours) without doing anything else with it? Will it automatically slide-show through the images and will they be full-screen? What is the non-jpg file in the list for the thumb drive?
post #525 of 10646
ignore my question about the other file....it was a winzip thing...
The other questions are still valid...
post #526 of 10646
It's a personal choice. You can if you want, you don't have to if you don't want. If you don't make sure you DO NOT use the break-in settings provided from D-Nice. Those are only for viewing the images meant for breaking in.
post #527 of 10646
Ditto.
post #528 of 10646
Pioneer 5020FD/6020FD Reference Settings (Can be used with (after) or without the recommended break-in procedure)
Picture:
AV Selection: Movie
Contrast: 38
Brightness: -1
Color: -4
Tint: R1
Sharpness: -15
Pure Cinema
Film Mode: Advance
Text Optimization: Off
Orbiter: Mode 2
So is this the only setting for the 5020? I didn't know if you had different setting suggestions for bluray vs tv etc.
post #529 of 10646
Hi all,
I just finished breaking in my 151-fd elite using d-nice settings and dvd.I hooked my vip 722 receiver and using d-nice settings to watch my hd cable.I had a samsung led 52" lcd earlier which i sold for kuro and kuro blows it away.Even my wife who fought with me not ot sell it says this tv is awsome.I love this set.Damn good.
Just one thought though.I feel whites are not as good as my samsung.Even my wife is telling this.Whites appear very very dull to me especially on a fullwhite screen.Is this the trade off for plasma with lcd?The whites are the only thing (on a full white screen)which is bothering me
post #530 of 10646
Also can anyone let me know how to set my vip 722 receiver remote to use for kuro.When the dish installer came last year he programmed dish receiver so that the switch on , off and volume controls of my samsung tv, i was able to do using dish receiver.Now since i changed the tv my dish remote is not working for this tv anymore.Any suggestions please
post #531 of 10646
The Dish manual will have the tv codes and instructions on how to set them. The new Pio's will not be there, try the various Pioneer codes till you find one that works, codes are usually carried forward.
post #532 of 10646
Got My Pioneer Demo Disk in the Mail today, this blu ray is jsut sweet. Totally shows off what this set can do. Best $20 i ever spent.
post #533 of 10646
Where did you order it from? What type of content does it have on it?
post #534 of 10646
I'm interested, too! Where'd you get the demo disc?
post #535 of 10646
When you hit play...did it buzz and display blotches? JUST KIDDING!!!
post #536 of 10646
It is a disk that Pioneer uses to promote there TV's. and I see why. It has various things on it to show off the black levels. nightime firworks kind of stuff, flowers, women is colourful dresses, solar system stuff, explanations of a couple of features on the tv. pretty sweet disk In my opinion. it has some classical music that goes along with it so u can have this disk running to show off the set while it plays the music.
post #537 of 10646
but where did you purchase it?
post #538 of 10646
Yep, reiterating the question... Where did you get it??
post #539 of 10646
lol sorry, i keep teasing... well i purchased it from a guy off of ebay. i think he has a bunch
because he let me buy one immediately and left his auction running. which is good because the auction went up to like 40 bucks or more.
this should help u guys
http://cgi.ebay.ca/PIONEER-ELITE-KUR...QQcmdZViewItem
post #540 of 10646
http://cgi.ebay.ca/PIONEER-ELITE-KURO-BLU-RAY-DEMO-DISC-2008-SEALED_W0QQitemZ330263627548QQihZ014QQcategoryZ617QQssPageNa meZWDVWQQrdZ1QQcmdZViewItem
