AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Biggest LCD under 36-inches wide? Any suggestions?
post #1 of 4
My brother is trying to get a TV however it has to be under 36-inches wide. ( Possible 35 inches)
Do you know of any TV larger than a 32-inch LCD that will fit in the space?
Thanks for your help.
post #2 of 4
I found one Here
If you look hard enough I am sure you could find something that would fit. A 37" is the largest you will be able to get.
Why must it be so small?
post #3 of 4
Originally Posted by mbyrnes View Post
I found one Here
There is a Cabinet designed for an old type of TV with doors that close.
Its an expensive piece of furniture that came with the room.
Thanks for the reply. I really appreciate it!
post #4 of 4
You could maybe...maybe...fit a Toshiba 40RF350 or 40XF550 in there...I think they are a shade wider than 36".
Toshiba also makes the 37RV530, which is about 36.1".
Edit: After re-reading your first post, if you only have 35" to work with, maybe a nice 32" is a better option.
