Originally Posted by
dbgary
I have connected an old DVD player to the Denon DVD input terminals using Y, W, Y composite cable. The output of the Denon is run to the TV with HDMI. The Denon plays the DVD audio but I can't get the video on the TV. Everything else seems to work OK.
...Anyone have any ideas on what I might have done wrong?
Just to be clear - you are using COMPOSITE (red/white for audio, yellow for video) right? And you plugged the red/white/yellow cable into the input labeled "DVD" on the back of the Denon?
Does it work if you connect video straight to the TV?
If so, as a troubleshoot, connect another composite (yellow RCA) video cable from the MONITOR OUT on the back of the Denon to a video input on the TV. see if it can at least pass through the composite video, so we can narrow down the problem to something with the analog > HDMI conversion.
