so you are trying to "stack" both the PS3 (with HDMI) and the 360 (component + optical) on the same input "name", correct? So they will both be accessible by selecting "DVD"?
1) make sure you actually REASSIGN the component input to the DVD name! You didn't have to physically unplug the cables, all you had to do was reassign them under INPUT SETUP > ASSIGN.
2) the PS3 has to be OFF for the 360 to come through. Otherwise the HDMI will take precedence. Also make sure Video Convert is turned on for the DVD input (INPUT SETUP > VIDEO)
thanks batpig!!! you are a great help...I read the thread and i have yet to install the latest realtek HDMI audio driver (2.13)...Maybe that'll help
I'll report back.
Reporting back...Installed the realtek HDMI driver and when I did that and went to my sounds control panel it showed the realtek driver but it also showed it to "device disconnected" and no other HDMI output was availible so I uninstalled and now i don't know what else to try or do..I guess i'll go back to the original HDMI output re-applyed itself on the uninstall. However, i'm wondering if there's something i can do in the BIOS to make sure the HDMI output is from the audio chip in the card (says it supports 7.1) and not from the MB. I'm lost...
