Originally Posted by
fakeplasticdream
I just got an 889. I added it to my Harmony remote, but it seems a lot of functions are missing.
Has anybody else found this to be a problem?
I emailed support. So we will see, but I read a lot of posts in the 789 thread with this same problem. It seems like they don't want to do it or something.
On one of batpig post in the 1909/789 thread page 6 link #152: As others suggested, just use any other Denon model, they all have essentially the same remote IR commands. I have been using the codes from my old AVR 2105 for a 3803, 1905, and now a 2307ci. It wasn't worth the trouble to delete the old device and add a new one, and all the codes are the same anyway. I ended up teaching the Harmony the "RoomEQ" and "Night" buttons from the remote, but that's all I had to change for my current setup.
You may have to try a couple or maybe teach the Harmony a couple random things from your remote. Try one with Audyssey features (like 2807, 2808, etc) so you can get access to those buttons.
Also check batpig post page 82 link #2439: Over in the 2809/989 thread, poster The Soapbox Kid listed a bunch of Hex Codes for discrete Dynamic EQ/Vol settings as well as surround fields. Any ones that you want added to your account, you should copy/paste them into an email to Logitech Tech Support and say you want them added to your account.
You should also call them up and bitch at them to add them to your account and complain that they aren't in the general 1909/789 code database, because several others have been pushing them on this.
Here are the hex codes for Dynamic EQ/Vol settings:
http://www.avsforum.com/avs-vb/showt...0#post14644770
Here is the hex code for discrete HDP input:
http://www.avsforum.com/avs-vb/showt...5#post14890345
Here are the hex codes for surround sound modes:
http://www.avsforum.com/avs-vb/showt...5#post14702445
