post #1 of 1
I finally got my Aver Combo card working with ATSC and QAM. The only problem is the brightness was too dark. I couldnt figure out which settings were affecting the brightness. Then i found the TV Color settings in the NVIDIA control panel. This helped fix the brighness problem for the HD channels....the problem is the brightness on the regular channels was now too bright! There's only one setting and two different inputs are affected differently. What can i do?
Its an AverMedia Combo PCIe and GeForce 8600 GTS
