AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Philips 42" Plasma - Brightness Changes By Itself?
post #1 of 7
I purchased a Philips 42PFP5332D/37 42" plasma from Newegg in early April. Now, I'd be extremely happy with the TV, except my brightness and color values always decrease, at a random rate (sometimes 1-2 points per minute, sometimes 1-2 points per hour).
I wanted to know if anyone else is aware of this kind of a problem and whether there exists a known solution.
Thanks in advance.
P.S. I am using HDMI with a 720p signal coming from my cable box.
post #2 of 7
Do you have an Active Control setting which is active/on ??
post #3 of 7
No, I do not. I've tried playing with every configuration option, and have even upgraded the firmware. Still, the problems remain unabated.
post #4 of 7
Run the set for a while with very low settings and see if they change.
post #5 of 7
I have done that. It drops to about 20 for brightness and 10 for color... but never actually stops at a round number. I've never run the TV for more than 4-5 hours continuously, but if I don't adjust the settings for a few days, I usually find them in the 20s.
post #6 of 7
What firmware are you running ? Upgrade it or even go back to an earlier version and see if the problem persists.
post #7 of 7
I was running something that was 0.9b, and upgraded to 1.1
Unfortunately the problem still persists.
Thanks for your help and attention by the way.
