AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official Pioneer Elite BDP-05FD & BDP-51FD Owners Thread / Vs 1.32 DTS-HD MA
Official Pioneer Elite BDP-05FD & BDP-51FD Owners Thread / Vs 1.32 DTS-HD MA - Page 317
post #9481 of 30708
Originally Posted by hughman View Post
it must be true, robert said all problems would be history :d, all except that incredibly annoying feature i suspect.
post #9482 of 30708
Originally Posted by CHP_VR View Post
Awesome! Now we ask 300 times when firmware 2.0 is gonna be released!
news.
And we want it yesterday!
In fact how come it is not already here by now it should be.
post #9483 of 30708
Hey I said no later than the 21st, its only the 13th!
post #9484 of 30708
I just received December issue of S & V magazine. They reviewed the 05. Overall, it is probably the most positive reviews of the player to date,but with the usual concerns (lack of Bd live 2.0, price, Dts-ma out of the box).
What I found most interesting was that they said SD playback was excellent. It passed most of their HQV torture tests and made even their marginal-quality transfers look crisp and presentable. I have always said this of the SD playback of this player in my system. I have never seen my familiar sd movies look so good! The same movies going thru either the reon processor in my receiver or played back on my Toshiba XA2 with the reon, do not look as nice as the 05's own processor. I am only stating what I see. My calibrator (umr) agreed with this and suggested that I let the 05 do the upscaling. This player seems to be back on track as the best Blu-ray player currently available.
Is it possible that the 05 upscales better than the 51?
post #9485 of 30708
I doubt it, but it's not impossible. Same hardware and same firmware used on both platforms. The only way it could differ is if the FW was set up to detect what player it was in and used a crippled algorithm for upscaling in the 51.
That would be really, really silly though.
post #9486 of 30708
Good news about the pending 1.17 release, although I've experienced pretty good performance under 1.08b. Curious if there are any image enhancements under 1.17?
post #9487 of 30708
One of the leading german on-line AV sites has just tested the european equivalent of the 05FD and gave it 'Reference Status'.
Two negatives:
1. Drive speed (too slow)
2. No 720p output
http://www.areadvd.de/hardware/2008/...bdp_lx71.shtml
post #9488 of 30708
So 1.17 has made it through legal?
If not, then methinks we have a longer wait.
post #9489 of 30708
I love my BDP-05 and have had no problems at all with any disc to date.
I've also been a subscriber to Stereo Review, now Sound and Vision for close to forty years. I dont ever recall reading a negative review in that magazine. They are eternally optomistic about every piece that comes thru their door. Take it for what it's worth. Julian Hirsch was a good man, God rest his soul, but sometime I thought he had tin cans for ears!
post #9490 of 30708
Originally Posted by Gary Murrell View Post
OK I decided to dig into the white crush problem a little more deeper and did some further testing
05fd(v1.08) set to 4:2:2 source direct and professional video, it is feeding a DVDO VP50pro, DVDO VP50pro is feeding my NEC XG CRT projector via 1080p/60 4:2:2 HDMI
when set to professional the 05fd showed every bit of white detail all the way out as far as possible(a good test disc for this is a AVS custom blu-ray test disc)
here is the kicker, when I set the 05fd to memory 1 and dialed down the white level to -1, guess what happened? it crushed some of the upper end
white level performance is perfect on my end when feeding the DVDO VP50pro scaler and leaving the unit set to professional, as as I said when engaging the -1 white adjustment it actually negatively effects the white performance on my system
I am very sensitive to white crush and will not tolerate it, the 05fd is not crushing whites on my end, make of that what you wish
-Gary
Truly bizarre Gary, the mystery deepens.
post #9491 of 30708
So true!!!
post #9492 of 30708
Originally Posted by Ruined View Post
Good deductive work Rob/edd/Gary! I am not going to recommend any alterations from professional/memory defaults then to retain ref. levels, since it appears to be a display issue.
I think we're far from knowing that for sure. As an example, I see no reason why lowering white levels 1 notch should result in a total shutdown of above white on a display other than the Pioneer as Gary found out. That too doesn't sound like normal behavior.
post #9493 of 30708
Originally Posted by nugga22 View Post
While I agree it shouldn't be recommended to change memory modes because we don't understand what is going on, I don't agree that it is a display issue. Something very odd is happening here. Late last night I checked white levels using my BD30 and everything was perfect. Same Kuro 111, just a different player. Swapped in the 51 and whites were crushed. It sounds like it is a combination issue between the 51 and 9G Kuros...which just doesn't make any sense.
Precisely Nugga! That's what I was saying before, there is some weird interaction going on here. Plus the fact that I too have had other players hooked up and saw no white crush. Add to that the fact that I don't believe I've ever read the Elite 9g's having white crush issues and you really have to scratch your head.
post #9494 of 30708
Welcome to the joys of HDMI!
I actually don't perceive this as an HDMI issue. This definitely seems to be some engineering issue that we haven't gotten to the bottom of...but we will.
post #9495 of 30708
BTW, are those having the crushed whites using 4:4:4 or 4:2:2 ?
-Gary
4:4:4 Gary
post #9496 of 30708
All of which raises a new question. Why is setting the 05's white level to -1 introducing white crush in your system ? One has to wonder what +1 would do.
Yup! My thoughts precisely. There is just something weird about the 51/05 output in some setups.
post #9497 of 30708
Originally Posted by DTV TiVo Dealer View Post
Here's the latest on the next firmware update. I have good news and yes, more good news and if that's not enough I have even more good news.
First, the firmware update for the BDP-05FD and the BDP-51FD have just been approved and we may see it posted on Pioneer's site as soon as tomorrow. DO NOT CALL PIONEER AS THEY WILL NOT KNOW ABOUT THIS TILL TOMORROW. You heard it first from me on AVS Forum and my information is spot on.
Second, we now up to release "1.17".
1.17 speeds things up greatly and resolved the audio and video compatibility issues that have been reported.
Enjoy!
-Robert
Robert, this would indeed be great news! Now I'm assuming the posted firmware will be 1.17 and not 1.12?
post #9498 of 30708
-Gary
4:4:4 Gary
try 4:2:2
4,4,4 requires more horsepower for negligible benefits per Jim Peterson of Lumagen
post #9499 of 30708
Originally Posted by D_B_0673 View Post
try 4:2:2
I suspect you're right about the benefits of 4:4:4
post #9500 of 30708
Hi Everyone,
Sorry for not being here for the past few weeks... I just got approval from our QA division to have the new firmware posted today... It should be up on our website in about 2 hours..
It is version 1.17...
Lots of speed improvements and it should resolve the disc compatibility issues that have been reported...
Please let me know what you thing once you get it installed...
Chris Walker
Pioneer Electronics
post #9501 of 30708
Originally Posted by Walkamo View Post
Hi Everyone,
Chris Walker
Pioneer Electronics
Nice to see you back Chris - welcome
post #9502 of 30708
Hi Everyone,
Chris Walker
Pioneer Electronics
Glad your back Chris...
Dana
post #9503 of 30708
chris is not missing after all
thanks for the update!
post #9504 of 30708
Hi Everyone,
Chris Walker
Pioneer Electronics
Fantastic Chris! Glad to have you back!
Don't be such a stranger around here...........please, he said in his most respectful tone of voice.
post #9505 of 30708
Hi Everyone,
Chris Walker
Pioneer Electronics
Chris you are the BEST! Thanks for the confirmation and your dedicated work in getting this player up to its exceptional ability.
-Robert
post #9506 of 30708
Hi Everyone,
Chris Walker
Pioneer Electronics
Look who's back
Posted today this is good. Sadly I don't have disk issues to really test. Meanwhile, I am anxious to test the speed improvment
post #9507 of 30708
Thanks Chris!! This is exciting news. I can't wait to download it when I get home tonight.
post #9508 of 30708
So, 1.12 was never released, it got bumped up to 1.17?
Eh, nice.
post #9509 of 30708
Hi Everyone,
Chris Walker
Pioneer Electronics
Chris; thanks so much for posting this and not giving up on us! I knew you guys would come through. Thanks again Chris, and don't let us run you off.
post #9510 of 30708
Much appreciated, Chris.
Oh, and welcome back!!
