You are forgetting the other obvious (and cheaper) route. Go buy a $50 Toshiba DVD player for your Magnavox recorded disks that won't play on the Oppo and save the Oppo for commercial disks and PC burns.
No, I didn't forget the option of replacing the Oppo. I just didn't want to go that route at this point.
s it stated anywhere that the choppiness does or does not occur when the DVD is played back on the same 2160 it was recorded on?
It wasn't mentioned. No, there is no problem playing back on it's own drive.
hook up a DVD recorder that is known to produce readable DVDs on the Oppo/PC by component output and try that
I don't have access to another stand alone recorder.
make sure that ALL the exposed 'mounting' screws are tight, and that would include the 'dock' for the DVD unit and the HDD unit. And also, get some good hard rubber feet on the bottom of the deck! Vibrations are murder to DVD Burning.....sometimes
I only opened up one recorder. I didn't notice any 'looseness' to the optical drive. The problem exists on both of the recorders, so I'm reasonably sure it's not that.
BTW, I would use soft rubber feet to absorb vibrations, not hard.
. I read the article after I posted the message. DOH! So it looks like if I order a newer 2160 I will be getting a SATA drive according to the post.
has no camera, no email, no texting function and it even has a real DIAL TONE. My wife and I could no longer read the buttons or screens on our TracFones so we went with Jitterbug.
