AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Panasonic 2006 and newer DVD drive hub/spindle cleaning and reassembly complications
Panasonic 2006 and newer DVD drive hub/spindle cleaning and reassembly complications - Page 3
post #61 of 79
Originally Posted by davearn View Post
I have the clunk-can't read DVD problem with my DMR-EH75VS.
The DMR-EZ48VK, available from Panasonic (Amazon) for about $260, has VHS + DVD recorder but no HDD. Wonder if cannabalizing the DVD recorder from this new unit, and trying an install into an old DMR-EH75VS, might work. Anyone with Panasonic repair experience know whether the DVD Recorder swap in would fit / work?
DVD Drives from 2006 models are not compatible with those in later models. For more information see this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1082922
post #62 of 79
Once in a while a question is asked about swapping a Panasonic 2007 or newer digital tuner into an earlier model Panasonic HDD/DVD Recorder that has an analog tuner. The answer is the same; it won't work. See this December 2008 post for more information:
http://www.avsforum.com/avs-vb/showt...7#post15278207
post #63 of 79
Good morning.
RE: http://www.go-gddq.com/upload/2009_1...2416522432.pdf
DVD-RAM/R DRIVE VXY1794 VXY1813 VXY1814 VXY1855
Has anybody tried to download this recently? I have with no success.
Are there any alternative sites available?
Thanks for your time.
post #64 of 79
Originally Posted by Bruce A View Post
Good morning.
Without problem I just downloaded the manual from that link.
post #65 of 79
It didn't work for me either.
post #66 of 79
Works for me.
The link for that manual does not work for me. Is it still active and my firewall is blocking it, or is the link really broken?
Thanks, it must be the firewall.
post #67 of 79
OK I had to try........works for me
post #68 of 79
Works on my end and I have my security settings set quite tough.
post #69 of 79
Thanks tomwil, I guess my memory is not too good in recalling the number of times I have tried to get that document. At least it's consistent!
post #70 of 79
for those of us who can't get that link to work?
Regards from cold Vermont.
post #71 of 79
That D/L link is good, try a different browser.
post #72 of 79
Great instructions. Helped to clean DVD Drive in my Recorder..
post #73 of 79
It worked for me.
post #74 of 79
guys, appreciate your help.
I have a Pano DMR-EZ485V that is giving me the "no read" message, and displays the disc symbol on the front screen with/without a dvd loaded.
it makes a clunking cycling noise 5/6x when the tray is closed w/w/o a dvd.
I tried the spindle/lense clean.
It looks like the spindle is too high, but I can't figure out how to take the final dark grey cover to expose the cam assembly.
any thoughts/suggestions appreciated.
any recommended service providers?
thx,
Phil
post #75 of 79
thx,
Phil
The cleaning procedures found in the second post in this thread are of no help when one has a failed laser assembly.
I've posted reassembly advice in two of my February 2009 posts in this thread, beginning here:
http://www.avsforum.com/t/1055071/panasonic-2006-and-newer-dvd-drive-hub-spindle-cleaning-and-reassembly-complications/0_60#post_15745506
post #76 of 79
DigaDo,
thx for the reply!
your posts are much appreciated,
do you think it is a failed Laser assembly, or the mis-alignment?
and, is the Texas panasonic service area the best alternative for repairs?
again, thx for your help!
Phil
post #77 of 79
DigaDo,
thx for the reply!
Phil
It is most likely that the laser assembly (optical pick-up) has failed.
The laser lens is loosely suspended in the laser assembly so that it "aligns" itself. There are no end-user adjustments.
Avoid the McAllen Texas Service Center. There are a number of McAllen "horror stories" that may be found in these pages.
For Panasonic service send a private message to mickinct. See this thread:
http://www.avsforum.com/t/1400807/part-2-having-issues-with-your-panasonic-dvd-recorder-read/0_60
Edited by DigaDo - 2/2/13 at 10:55am
post #78 of 79
Thank you DigaDo!
you have been helpful to a novice...
have a good day!
Phil
post #79 of 79
I have a BD65 (Blu-Ray player) that all of a sudden stopped working with DVD and Blu-Ray disks. I wouldn't consider it a heavy-use machine. Oddly enough, it seems to still be able to play a MP3/CDRW no problem. DVDs and blu-rays both fail with noread / check the disk / incompatible disk type errors after the machine attempts to identify the type of disk (and fail).
Based on information in this forum, I checked (and cleaned -- even though they looked amazingly clean) the rubber around the spindle and the lens.
When a disk is inserted, it makes the normal noises of the read assembly going back and forth and the disk spinning up. When I put a disk in it, (with the cover off the drive) I can see that the red laser definitely works, I can see through the disk that the mechanism attempts to focus the beam on the disk , and the blue laser does light up, although it is only on very briefly. The IR wavelength seems to work fine, since the CDRW is playing.
Is there anything left I can do besides go buy another Blu-Ray player? (I'm inclined to avoid panasonic at this point, since this is not the first to suffer a similar fate). These machines can be had for $100 or so, so it's not really worth taking to a repair shop . Suggestions?
  Back to Forum: DVD Recorders (Standard Def)
