AVS › AVS Forum › Audio › Receivers, Amps, and Processors › onkyo 905 remote control via lan interface
post #1 of 6
in the setup at the network settings from the onkyo 905 have i see "remote control" and "port 60128" how does it work ?
:edit
http://www.amazon.com/Onkyo-TX-NR905.../dp/B000OBJW2C
amzone write something about "onkyo e-control system", what is onkyo e-control system ?
post #2 of 6
Pieter
see AVS thread no. 765113
Works great with my 905.
Rgds
Chris
post #3 of 6
how can i see avs theard no 765113 ?
-> http://www.avsforum.com/avs-vb/showthread.php?t=765113 ?
than i see
vBulletin Message
No Thread specified. The post or the thread may have been moved into the archive.
Please try clicking HERE to read the archived posts or threads prior to 2005.
Or HERE to read the archived posts or threads between 01/05 - 06/06.
If not found it was more than likely removed. If you need further help, please notify the administrator.
post #4 of 6
Sorry, try avforums.com (not AVS).
It contains an ISCPRemote Server that you can use to send commands to the Onkyo via LAN (once you have enabled web control in the set-up).
Rgds
Chris
post #5 of 6
post #6 of 6
okey, thanks
