Originally Posted by
jhego
I have TWC Southern CA and i believe they use iGuide. We have a non HD downstairs and it seems unresponsive and slow at times. So should i decide on the box based on the software? How about picture quality? Is it significant between the 2? If both are similar in terms of features, then i prefer the Moxi software. Haven't really thought of Tivo. Would i need both the cable box and tivo? or does it work alone?
I didn't notice a difference in PQ, but using HDMI did clean up the cables quite a bit
MOXI has more features than iGuide, but iGuide will generally do what you need it to do (pause, rewind, record).
I had to trade in my MOXI because the drive was too small and we weren't going to get the 4.1 software which allowed external drives.
I still have a DCH3416 in the bedroom for VOD or in case SDV hits before the tuning resolver, but I much prefer TiVo.
The TiVo HD just requires a cablecard from your cable company to work. You can add external storage, schedule from the web, download videos from Amazon, etc. Watch out for
SDV - check your
local thread. TWC is aggressive with the roll out from my understanding; and until the
tuning resolver is released, you might not be able to get all their channels with TiVo.
jhego
also, are u able to record by setting time frame, instead of the whole segment. For example, I just want to record the basketball part of the olympics, so i would like to set 2am-4am instead of recording the whole olympics. Reason is space.
Yes, both iGuide and TiVo allow you to set up manual recordings.
