I have been burning AVCHD discs for a year or two now - burned several thousand programs this way with great results. And although I have been very happy with the great HD quality, I have often been frustrated with the limited amount of space. I capture the majority of content from my HD-PVR using 1280x720 input at 7.1 Mbps variable, which provides excellent HD PQ for the majority of content, but it generally limits me to about 3 hours of content on a standard DVD-R.
I have wanted to start using BD-R for the 25GB size, but all the software I had tested insisted on re-encoding all the TME captured files, generally greatly increasing the file size and often reducing PQ. And I won't even mention the unbelievable amount of wasted time waiting for those unwanted and unnecessary recodes! What I wanted was a simple way to just put the exact same files I was burning to AVCHD DVD5 blanks to BD25 blanks. And I finally found it!
If you already know how to create an AVCHD with the TME software you got with your HD-PVR, then you ALREADY know everything you need to know to create the larger 25GB discs. And you can test it for free.
My process is as simple as this - I just edit the files and create the menus in TM Studio, just like I always have, but I keep adding programs until the displayed output size is up to 25GB. Then I simply burn the compilation to the HDD instead of a disc. Finally, I just use the 'write data' function of DVDFab Blu-ray Copy to write the TME output folder directly to a BD-R without any editing or recoding at all. No knowledge is needed here - there is nothing to do other than simply click on the 'Start' button!
I end up with a 25GB AVCHD disc that plays exactly like the 4.7GB discs.
Blu-ray Copy is not free, but it is VERY reasonably priced, and it has lots of functionality beyond simply burning these discs. I have found DVDFab products to be great, and the company provides outstanding support.
In my opinion, the beauty of this method is simply that you do not need to struggle with other unsupported and generally unfriendly software, and there is absolutely zero learning curve. You create the disc with menus just like you have been doing, and then copying it to the BD25 is absolutely nothing more than selecting the correct folder and just clicking on a 'Start' button! DVDFab products have a free 30 day trial, so testing this won't cost you a thing - you have a full month to try it out and see if the ease of use (plus the additional copy/burn capabilities) of Blu-ray Copy are worth the $50 or so to you. If not, keep struggling with the free stuff!
No longer recognized on my HTPC and when I plugged it into my laptop, same result. Bummer. I wish there was some magical reset but I don't think so.
