I love my 1212. Works great.
I've been around here quite awhile, I've never heard any other editing software for h.264 recommended as much as videoredo. I think you should try TME editing and figure out how badly you want videoredo.. Do you actually want to spend 30min editing commercials or 30sec using the FF button?
Capture Bit rates depend on content. How fast moving is the video?
Start here and tweak as you like. These should be safe values with great quality. There's nothing worse than having to capture a 2hour program twice because I wanted an extra .5kbps.
I use variable not constant..
720p/5.1 source:
60min 12.0vr dvd5
90min 10.0vr dvd5 13.5vr dvd9
120min 12.0vr dvd9
1080i/5.1
60min 11.0vr dvd5
90min 11.0vr dvd9
120min 9.0vr dvd9
If there's just one title on the disc I use tsmuxer to author. You can choose whatever auto chapters you want (5min for example) and it's fast. (no menu)
If there are multiple titles per disc I use multiavchd for authoring. It can create menus and auto chaptering.
Burn using nero or imgburn.
I think these are the easiest tools to use. Not saying the best, just pretty easy..
720p/5.1 source:
60min 12.0vr dvd5
120min 12.0vr dvd9
1080i/5.1
60min 11.0vr dvd5
90min 11.0vr dvd9
120min 9.0vr dvd9
