AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Apex DT502
Apex DT502 - Page 12
post #331 of 338
Originally Posted by Beeper View Post
It's a 300 ohm flat lead connection with a coax adapter. I think it's early 70s, or late 60s.
It received some Morning Dove poop on it, but otherwise it has held up.
It picks up Grand Rapids about 110 miles away.
Sounds good. I have what's probably a similar one in my attic and it works really well. I had to move it to a fiberboard gable side after I had a metal roof installed, actually works better than when the previous owner had it pointing through the cedar shingle roof (rain); I think they were being cheap with cable as it had flat lead that was barely long enough, I never could rotate it exactly where it needed to be either the cable was so tight. With the relo I changed to coax adapter at the antenna and coax.
I used this site, nice graph and can tune for trees, height, etc.: http://www.antennaweb.org/default.aspx
I'll have to check out that TVfool sometime.
post #332 of 338
For the channel 68 (RF 5) that doesn't tune on the Apex, TVfool shows LOS 6.7 miles NM(dB) 67.1 PWR (dBm) -23.7.
The tower farm has all of the full power antennas in a 16 degree range from my location, and I split the difference with my antenna aim.
That sounds like WIWN. Tvfool for Milwaukee:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3de779a612f63ff0
Maybe it's overload, or maybe it's this from http://en.wikipedia.org/wiki/WIWN:
On August 12, 2012, it was reported that the station had began to broadcast from the MPTV Tower, airing programming from WeatherNation and using the new calls WIWN-TV, which became official on August 13, 2012.[6]. A week previous, Weigel had moved their independent station WMLW from low-power Channel 41 to the Channel 49 full-power signal of WBME, which carries Me-TV programming with both stations switching their calls, and began high-definition operations for WMLW, suggesting a challenge to WIWN in some way.
I tried aiming directly at each end of the 16 degree range, and found little difference in signal strength.
If you have maxed out the signal strength indicator, there will be little difference in strength.
The Apex that Trip in Va is using at home for WBRA, RF3, is more sensitive than his Zenith DTT900 for VHF-low.
Edited by rabbit73 - 8/31/12 at 6:17pm
post #333 of 338
Originally Posted by Floydage View Post
There used to be a page ( http://en.wikipedia.org/wiki/Comparison_of_CECB_units ) that showed the tuners used within the boxes but the content has evaporated; I bet someone here in AVS land has it archived though.
It was saved by holl_ands:
CECB Feature List
http://imageevent.com/holl_ands/files/ota
post #334 of 338
CECB Feature List
Excellent, thanks! Doesn't look exactly the same, rather a vastly improved DIY version as if he used it for a template; plus I get a bonus set of other interesting and useful documents. Man where was this doc when I needed it? smile.gif. I see some models that I didn't know had multi-day EPGs, of course they may have been long gone by the time I needed to burn some CECB coupons. I remember a group of us AVSers didn't know about TRT (one model looking to be the ultimate box on paper) until a week or so after the program expired tongue.gif.
As I suspected the DT502 appears ("?") to use a different tuner than the DT250s; possibly the brain (SoC) too. Also note the Pass Thru difference (DT250A) which is most likely done in the tuner module (integration - otherwise it would have to connector to an external switch then to the tuner). I would think Samsung makes a good tuner. Hmmm, maybe overload like you suggested if everything is working properly; sounds to have good sensitivity in the VHF low band and RF 5 is the only channel he has in that band.
I didn't understand the "...suggesting a challenge to WIWN in some way." Some way? biggrin.gif
post #335 of 338
My remote control for the Apex DT502 is broken. The box is useless without it. Can I get a universal remote? Or am I screwed and have to buy a whole new unit? The remotes are no longer for sale on the internet.
post #336 of 338
Some of the ALL-IN-ONE R/C devices will control MOST of the CECB boxes, as I responded to a similar problem for a CM7000/CM7001:
http://www.avsforum.com/t/1457527/channel-master-cm-7001-remote-control-code-for-universal-remote
Be sure to check for APEX CECB (Converter Box) box support in the User Manual for any desired R/C device.
post #337 of 338
I do see used remotes for the Apex listed on eBay regularly.
I had asked in forums in the past if there is a remote code for universal remotes to work the Apex, but I didn't get any replies.
When these boxes die, the remotes usually end up on eBay.
I have one dead box, so I have a spare remote for a second box.
post #338 of 338
Out of the box, my Apex R/C barely worked at all, a common complaint. So I would advise against a USED one.
I see Apex DTV Converter Boxes in the manuals for the fol. two inexpensive R/C units:
http://www.oneforall.com/support/manual [Same R/C's and manual link cited in post #336 above]
FYI: Most Converter Box codes are also found in the Harmony R/C database, if you already have one.
All-In-One OARH04G 4-Device R/C ($12) supports most CECB's (called DTV CONVERTERS), but does NOT support LEARNING from another R/C. PS: Amazon et. al. incorrectly claim that this R/C supports LEARNING....it does NOT:
http://www.oneforall.com/uploads/support/628ee2d0046b922840ac6ebf61b50703.pdf
All-In-One OARC05G 5-Device R/C ($17) adds ability for LEARNING from another R/C, something that can be of value even for "supported" devices, since they always seem to leave out some of the less frequently used buttons:
http://www.oneforall.com/uploads/support/a48b2139fd2522b897761877f8f02750.pdf
Also (there may be more that support CECB's, aka DTV Converter):
All-In-One OARN08G 8-Device R/C ($18-25) with LEARNING:
http://www.oneforall.com/uploads/support/ac9dea51bde250afae0394cdcd442c48.pdf
Edited by holl_ands - 4/30/13 at 6:47pm
