When you are viewing the EPG, you select the program you want to watch with the up/down arrows, then you press the OK button to put a checkmark next to the selected program. The box will then change to that program when the time arrives. It does not turn the box "ON."
Best Buy is the only place I know of to purchase this box. Also, be aware that APEX is now producing an "A" model. I don't have it, so I can't tell you what it does. WIKI shows that it doesn't have S-Video or Smart Antenna.
