AVS › AVS Forum › Display Devices › Direct View (single tube) CRT Displays › Sony DA4 Chassis Owners (HD Tube TVs from 2002-2004~) I need your help
post #1 of 11
I accidentily reset my MID NVM data a while back but using the initial/average defaults listed in my service manual has yet to get 480p and above to display on the tv.
Luckily I found that enabling HDPT will bypass all mid settings while dealing with a 1080i signal allowing it to display on my tv from either DVI or Component Sources.
There have been others who have dealt with this kind of issue but they appear to no longer be active all attempts to contact them on my part have resulted in failure.
So for those of you who own a Sony HD Tube in the HS510, HS410, and XBR-9xx families or a model close to them could you please share with me your MID settings?
(I backed up only the first four MID 3 values before the wipe but they aren't giving me anything of values so I believe its the settings other than Hsiz, Vsiz, Hpos, Vpos that are causing my problems)
post #2 of 11
Do you have a service manual for your set? Not just the spreadsheets but the actual manual? What set do you have? If you have the actual service manual, have you set all the values to their defaults?
post #3 of 11
Yes I do have the proper service Manual for my model(KV30HS510) but following the Initial settings for all of the entries hasn't been advantageous in all circumstances.
For Example
480p, 720p, 1080i, and index/favorites/twinview did not work at all with default values.
I found through dumb luck at first that turning on HDPT allows 1080i to bypass MID entries this made 1080i work again. Bypassing MID to get 1080i back informed me that my problems were in MID.
Just a few minutes ago I have come a little bit closer to fixing those issues. MDLO which is recommended to be 12 by all DA4 chassis service manuals have read. A MDLO setting of 12 only causes visual garbage and some times a 1 second capture of RF to appear on screen when ever I access Component, DVI or the secondary display in twin view basically anything that refers to MID Data.
right now I have MDLO set to 0 and I find that 480p now works for the first time in weeks albeit imperfectly I bet some geometry fine tuning will fix that 720p and the secondary video view.
If I could get someone elses mid setting I'm sure I could do this quicker
post #4 of 11
I have a 32HS510, that is under construction. It is not a widescreen model, which mids do you need? There are a LOT in my service manual!
post #5 of 11
^thx jdre
the mid 1 through mid 3 settings that are actually in use on your tv would be nice
Woot I got 720p back!! 1080i with or without HDPT I also have 480p back but it looks super washed out for some reason
I owe a bit of thx to a poster I tried to help http://www.avsforum.com/avs-vb/showp...32&postcount=1
If not for getting the service manual for his model I would have never found out what all the acronyms meant and I would have never figured out how to fix things myself.
post #6 of 11
I will take a look, and write them down on the service chart. Might take a day.
post #7 of 11
.......Just a few minutes ago I have come a little bit closer to fixing those issues. MDLO which is recommended to be 12 by all DA4 chassis service manuals have read. A MDLO setting of 12 only causes visual garbage and some times a 1 second capture of RF to appear on screen when ever I access Component, DVI or the secondary display in twin view basically anything that refers to MID Data.
FWIW, the KV34HS510 service manual indicates MID1/MDLO=6 for all covered models (US KV32, 34 & 36HS510)
post #8 of 11
lol that is like the only service manual for models close to mine that i didn't bother checking
the xbr 910 data sheet, hs420 sm, kv30hs510 sm, xs955-xbr960 SM all suggest an mdlo of 12 and not having a clue about what it did I didn't second guess it.
Seriously Sony need better checking for their manuals between that and entries where the suggested value exceeds the range its a wonder that the techs were even able to calibrate them at all
post #9 of 11
I still need to get to the settings, might be a few days.
post #10 of 11
KV32-HS510, running over the air regular TV, no, HDTV signals available
MID1
0 DHPH 111
1 DVPH 20
2 DHAR 240
3 DVAR 135
4 DHPW 55
5 DVPW 5
6 DYCD 3
7 DYSD 4
8 MDHP 0
9 MDVP 30
10 MDHS 240
11 MDVS 120
12 MLHP 31
13 MLVP 30
14 SDHP 167
15 SDVP 5
16 SDHS 115
17 SDVS 79
SKIPS 18-21
22 DPSW 0
23 MDLO 6
24 BCOL 1
25 DYSS 1
26 OSDH 32
27 OSDV 16
MID2
0 DRHP 117
1 DRHS 180
2 DRVP 37
3 DRVS 120
That is all it had in MID2
MID3
0 VDHP 74
1 VDHS 161
2 VDVE 19
3 VDVS 135
4 VDV0 0
5 VCPO 40
6 VCWD 3
7 VYCD 0
8 VSTP 144
9 VSTT 0
10 VHSC 130
11 VFRV 0
post #11 of 11
Were the settings any help?
