Thanks for the answer
To be honest your view on the situation seems to be very onesided Rgb, atleast that's how it seems to me. It seems as if you're throwing out alot of info/"smoke grenades".
I have no problems playing most BRDs in Windows, so saying that it's not worth the effort is just wrong imo.
Setting up a HTPC is alot of work no matter what solution you choose, and the extra 15 min it takes to set it up to play BRDs aswell.
I play ripped HD-movies aswell, but some disks I prefer to have in "full format", so untill playback of BRDs is supported in Linux, it simply isn't an option for me, and many like me. But the day that it can be don I'll look into using Linux.
And as far as I know you can remove all the DRM-stuff from the complete-disk rips anyway, so HDCP really shouldn't be a problem.
