Hmm I need some help deciding which motherboard to pick...
These are my other spec:
Silverstone gd02b case
Corsair 520w PSU
2x2gb 1066 DDR-II
1 tb spinpoint HD
Radeon HD4850
AMD Athlon x2 5600+ (2.9GHz)
DVD-burner
windows vista
Basiclly my question is whether it is worth for me to wait for a 790gx micro-atx motherboard when I will not use the IGP. Is the sb750 worth the wait?
Also I have to consider the higher price of the new 790gx compared to existing motherboards. Are there any other motherboard out there that will serve my as good as the next generation motherboards?
Thank you in advance!
Corsair 520w PSU
2x2gb 1066 DDR-II
1 tb spinpoint HD
Radeon HD4850
DVD-burner
windows vista
