I just finished building my new HTPC and thought you all might like to see some pics in case you were ever thinking about using an Omaura TF11 case. This case is almost impossible to buy now. However, there are not many cases out there that allow you to drop in 6TB of storage and I was able to work around it's short comings. Parts of the build where really a pain since everything is a very tight fit and I am a little anal about cable routing.
Let me know if you have any questions, suggestions or opinions.
Part list:
Case: Omaura TF11 (IR kit)
MB: Asus PQ5 (Intel P45)
CPU: Intel E8400
Cooler: Scythe Ninja Mini (Enermax UC-8EB fan)
Ram: OCZ Reaper HPC Edition 4GB
Video: Asus ATI 3650 Silent replaced with Asus nVidia 9500GT
HD: WD 1TB GP (x6)
OD: Lite-On Blu-ray
PSU: SeaSonic M12II SS-430GM (430W)
Case Fans: Enermax UC-8EB (x2)
HD Fans: Zalman ZM-OP1 (x2)
Keyboard: Logitech DiNovo Mini
Display: Samsung 52" LCD (LN52A650)
AVR: Denon 4308ci
OS: Vista Ultimate 32bit
Future Upgrades: Asus ATI 4670; Asus Xonar HDAV1.3 and a 2.5" OS drive.
Pictures (picasa web album)
EDIT #1:
I have finished the build and got most of the software installed. Everything pretty much worked right away.
As for the Omaura case... everything worked out for the most part. Mounting the Blu-ray drive is a pain, anyone using this case I recommending removing the default screws and using the little black ones for mounting the drive. Also I had to put a good amount of force to get the PSU in place. If you look at one of the pics I uploaded you can see how badly made the back of the case is made. I cannot screw in my video card at all. Luckily with the MB laying flat that isn't a huge issue. Also, get rid of all 4 fans that come with the case. They are complete crap. Use your favorite 80mm fans in the back and then install two Zalman ZM-OP1 under the hard drives. Be sure to also install a Zalman fanmate to slow them down or they will be too loud. Also, I highly recommend ordering short SATA cables. I used a combination of 4" and 6" cables.
Overall I am really happy with this build. It is a lot quieter than I thought it would be, I can't hear it at all from my couch 9ft back. I need to monitor the temperatures over the next couple of days but first impressions don't seem too bad. I think the Omaura TF11 is still the best HTPC case out there but, it is such a shame there are some quality issues that pretty much forced them out of the American market.
EDIT #2:
I have replace the ATI 3650 with a nVidia 9500GT. This was mainly due to 24p performance with TMT. Uploaded newer pictures that show the nVidia 9500GT and with all of the SATA cables installed.
Part list:
CPU: Intel E8400
HD: WD 1TB GP (x6)
OD: Lite-On Blu-ray
AVR: Denon 4308ci
EDIT #1:
EDIT #2:
shame about the case being tricky, I am going to build my HTPC in antec's fusion case, hopefully that will be a little easier
