AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung LNxxA630 Calibration/Settings Thread
Official Samsung LNxxA630 Calibration/Settings Thread - Page 27
post #781 of 800
i just bought the ln46b610 from costcos, i heard this is the same tv as the 630 except its the warehouse brand, is this true?
post #782 of 800
I dont think so. There are differences between the 610 and 630. For one look at the contrast ratio. I think it is 40,000 and 80,000.
post #783 of 800
I'm back with a quick update:
My original post is as close as you'll get to an ISF claibration without actually paying for one (that or go buy a colorimeter, yourself).
I retested a few weeks ago and the settings are still 'spot-on' for where they're supposed to be.
They're not perfect (A630's color decoder has obvious limitations), but should do for most everyone who wants 'accurate' color.
Hope I've been of help.
tril
post #784 of 800
I can't tell, but the 610 may be a less feature-laden version of the 630, or maybe it's a different TV altogether, since the case sizes are not quite the same. Take a look here: http://www.samsung.com/us/consumer/t...ZA&view_gb=ALL
I don't know if Samsung will tell you anything more, but there's an official Samsung support thread with a friendly Samsung rep over at CNET.
Btw, this thread is about the earlier A series. I assume there was one created for the B series where people could tell you more.
post #785 of 800
Is the Ln52a630 a 10 bit panel and/or does it have 10 bit processing?
post #786 of 800
oh dear
post #787 of 800
My impression is no (the 650 does). According to the Samsung rep at CNET's official Samsung forum, it's not a published spec. For more info, do a google search on the following: "10 bit" processing Samsung LN52a630 (and also without the quotes).
post #788 of 800
Thx 4 the reply...
After Calling Samsung I was told its a 10bit panel..They couldn't find
if it had 10bit color processing though.
With The set having xvYCC settings along with hdmi 1.3 jacks it made no sence that it wasn't a 10bit panel to me.
post #789 of 800
Anyone have a updated caliberation for the LN40A630?
TKI gave me his which is VERY nice looking on my set. Thanks again TKI!
Anyone else have one they would like to share?
Thank you
-Chas
post #790 of 800
I could not find an official owners thread for the LN52A630 so hopefully you guys do not mind me posting this question here.
I have owned my set for about 2 years now so it is past it's warranty. I have noticed that during dark scenes there are bright areas in the corners of the screen. It is not that noticable during bright scenes but damn it is distracting during dark ones.
I believe the issue is known as clouding and after using google until my fingers bled I came to my senses and came here. Is anyone else having or has anyone else had this problem? What would be the solution? I am holding off on calling a samsung tech because I am deployed at the moment. I will do that when I get home if that is what has to be done.
post #791 of 800
Check out the official CNET Samsung forum at http://forums.cnet.com/samsung-forum/. There's a rep that actively monitors threads and, to the extent Samsung permits, helps steer people toward help.
post #792 of 800
Hi folks,
Triladar,
I've been using your settings for quite a while now with some small adjustments, thanks for that!
Quick question on something that may have no meaning...
I noticed that when watching my tv through Direct HD DVR box that when the screen comes on the title in the corner shows my input device and also says 60hz, I understand that the tv is 120hz. Does it show as 60 because my auto motion plus is turned off or is there some other setting that I may not be taking advantage of?
thanks to any replies.
Rob
post #793 of 800
The *source* will be 60 Hz, the box is showing the frame rate of the source. The TV doubles that frame rate, and displays 120 frames/second.
post #794 of 800
ah gotcha, thanks so much.
post #795 of 800
the ps3 settings look better for the 360 settings than the 360 settings
do with TKI's
post #796 of 800
anybody want to post the latest and greatest settings?
post #797 of 800
Does anybody have TKI's last settings? All of the updates have a link to post #174, which say REMOVED.
post #798 of 800
Just got off the phone with Samsung regarding HDMI Black Level greyed out for all sources/resolutions, including movie mode and interlaced. Their answer is that it just comes on when some compatible game systems are attached via HDMI. Don't know if I believe that but can't refute it. Model is 40C630K1F, code ......XZA.
post #799 of 800
Someone really needs to do a new calibration for this TV, anyone up for it?
post #800 of 800
please
