AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Trying to find a MFR for a Coaxial Cable Patch Panel
post #1 of 6
I'm looking for something exactly like this:
h t t p : / / www . l-com.com/item.aspx?id=8679
I tried to purchase this one over 2 weeks ago, but the company keeps giving me the run around about it not being in stock. I have a time sensitive project and need something sooner than that. I've been searching google & ebay for hours, but the closest similar item I can find are BNC patch panels. Anyone have any ideas where I can purchase one of these (and get it shipped very quickly)? I'd like to find one elsewhere and cancel my order at this other shady company.
BTW, requirements are it has to have at least 24 ports and be able to fit in a 2U rack mount enclosure.
post #2 of 6
I'm going to use a 24 port blank keystone patch panel for this. I have the unit installed in my rack, but have not added teh connectors yet.
Here's a typical unit without the keystone F connectors installed:
http://cgi.ebay.com/19-Rack-Mount-2U...QQcmdZViewItem
Here's the keystone F connectors:
http://www.cablesnmor.com/index.asp?...S&Category=172
CJ
post #3 of 6
That is what I am doing on mine as well. That way you can use the panel to patch multiple things.
post #4 of 6
www.fpatchpanel.com
I don't know anything about them, but I'll probably order a panel from them soon.
post #5 of 6
Originally Posted by eskay View Post
www.fpatchpanel.com
WOW...24 port for $80? You can make 4 of them for less...
CJ
post #6 of 6
try this one 24 Port Keystone Blank Patch Panel Rack Mount You can put any thing you want in it:
Example:
This one has speaker connections, RCA jacks, F-connectors, and RJ45
