Room: approx. 10 x 12 (x 9h) with one standard-door-size opening
budget: originally $200, but will go higher after reading other posts
use: 70% HT; 30% Gaming
size: small footprint is a plus, but not a requirement
Here's what I've found so far:
bic v1020 - $180shipped
bic v1220 - $215 shipped
Famous Maker 10" 100W Powered Subwoofer (by Dr. Hsu) - $270 shipped
http://www.partsexpress.com/pe/showd...number=309-175
velodyne vx-10 - $185 shipped
Dayton SUB-100 10" 125 Watt Powered Subwoofer - $150 shipped
elemental designs a2-300 - $315 shipped
bic H-100 - $249 shipped
Obviously, the a2-300 is quite a bit out of the pricerange I listed. But the Dr. Hsu 10" is something I can probably afford. Does anyone know anything about that sub and how it would compare with the a2-300?
Here's an idea! Pick out the best-sounding sub from the above list (feel free to add anything to the list that's in the same general pricerange). Assume that best sub on the list is a perfect 10. Then rank the other speakers along that same scale. This should give me an idea how bad the others are to the best I could afford so I can then weigh the cost/quality tradeoff.
