Got mine installed. Well I just set it up to listen to it. It was not loud at all and I was disappointed. But with a few adjustments and turning off audessey it is to my liking. Ill post some pics when my bananna plugs,speaker wire,audio rack and mounts come in. Pretty happy with it so far. And newegg does not mess around when it comes to shipping.
Speaker Type -
Front/Center 2-way, acoustic-suspension
Full-range, bass reflex 2-way, acoustic-suspension
Subwoofer Acoustic-suspension/Powered
Drivers -
Front 5" (12 cm) A-OMF diaphragm cone x 2,
1" (2.5 cm) soft-dome tweeter
Center 5" (12 cm) A-OMF diaphragm cone x 2,
Surround 5" (12 cm) A-OMF diaphragm cone x 2,
Subwoofer 12" (30 cm) cone
Frequency Response -
Front/Center 50 Hz–45 kHz
Surround 50 Hz–45 kHz
Surround Back 50 Hz–45 kHz
Subwoofer 20 Hz–100 Hz
Output Sound Pressure Level -
Front 83 dB/W/m
Center 83 dB/W/m
Surround 81 dB/W/m
Surround Back 81 dB/W/m
Subwoofer -
Max. Input Power -
Front/Center/Surround 130 W
Surround Back 130 W
Subwoofer -
Max. Output Power -
Subwoofer 290 W
Nominal Impedance -
Front/Center/Surround 8 ohms
Surround Back 8 ohms
Subwoofer -
Input Sensitivity/Impedance -
Subwoofer 330 mV/100 k-ohms
The reason why its not as loud as you like it is because the sensitivity rating on those speakers is a relatively low 83db or less. For comparison my Athenas are between 90-92db while my Energy speakers are between 87-88db.
You'll just have to get used to turning the receiver up louder than you would if you had different speakers. As long as it sounds good though, it is all that matters.
