Originally Posted by zAudioLover
I got mine shipped and the box was not in a good condition. The speakers and reciever did not have any dents.
I noted that when I try to switch off the reciever, the sub is still on; it does not go to standby. Has anyone got the same. Am I doing something wrong? If I put the reciver on standy (by remote or maunally), shouldn't the sub go to standby?
The sub doesn't go into standby at the same time you turn the receiver off. I believe it stays on for 3-5 minutes before going into standby itself. Yours is most likely doing the same (which is normal).
Thanks mate
The bottom has one of the stands completely broken off and missing and there is some damage to the wood on that same corner.
