Originally Posted by nil5
i say this half-jokingly.
in parallel with one of the speakers, attach an input to your computer's sound card (mic port?). then run a software spectrum analyzer so you can see the input signal spectrum at the speaker. Drive the AUX port on the receiver with output from your computer's sound card (line out) with a controlled test signal, and then you can measure the frequency response of the receiver. To calibrate the setup, you would want to loopback the output from the computer to the input of the computer.
Sounds like fun, no?
LOL, I'll pass. I've since gotten the speakers sounding good anyways. I did some listening and adjusting.
...you should be able to find another way to mount the speaker correctly without compromising the integrity of the speaker itself.
