Sorry if I'm posting this in the wrong spot. If there is somewhere better, please let me know.
I purchased the S9100THX about a year ago. So far everything has been working great. The other day however, I came home to find that my TV was no longer receiving a signal from the receiver via HDMI, when using my Satellite box as the source. My HDMI devices passing through my reciver all work fine. However, the Satellite uses S-video to hook into the HT-R960. I tried using a different cable, and a different satellite box and neither worked. I also tried connecting the wii up through the component input, but this did not work either. Trying different S-video ports also does not work.
Since I live with my two year old nephew, I figured he must have decided to 'play' with the receivers settings. I have gone through everything I can think of here, but I cannot seem to find any issue with the settings. The last ditch effort I had was to reset the receiver back to its default settings in case there was something I may have missed. After setting everything back up again, I still wasn't receiving any signal from the HT-R960 when I switched it to the Satellite box.
I'm pretty certain that the issue is with the upscaling from S-video to HDMI, but I have tried every setting combination I can think of, and I still can't get the signal come into the receiver via S-video and pass through to the HDMI output to the TV. The TV isn't receiving any signal from the receiver, no timing, resolution, or refresh rate information. Is there something obvious I am missing that I can try? Could this be a hardware issue? Any ideas or help would be greatly appreciated. If figures this would have to happen the day football season started...
