Originally Posted by 16x9enhanced
john--thanks for the info.
btw: I thought part of the idea behind going for higher wattage was to allow your speakers to be pushed more efficiently, and allow them to produce the sound they are capable of. Is this correct?
I understand that the actual volume may be no different.
Yes, the quality of the amplifier is more important than just the wattage output. Also better amplifiers can deliver their full power continuously, not limited to a specific length of time. Higher wattage amp's usually offer the necessary dynamic headroom to output power at a significantly higher level for short periods to accommodate musical peaks or extreme sound effects in films.
BTW here's a nice article Decoding Amp Power Specs that covers output power spec's.
Thus the 2809 is a bit better sounding then the 2309, just as the 2309 sound a bit better then the 1909, and you can hear this at identical volume levels with the same music if you compare them.
