Originally Posted by BRAISKI
Question about the DTS HD
I have the T2 Skynet edition and I tried to play DTS HD Master Audio and it seems that its not sending a DTS signal to the AVR, I mean the DTS light doesnt light on and its not playing. I also tried playing Quantum of Solace and the DTS indicator doesnt light one as well. Am I missing something?
Make sure you have the BDP-S360 set to "bitsream" the DTS HD-MA, as well has having the DTS HD-MA track selected on the BD, otherwise the S360 will decode it and send it PCM to the Denon and therefore "no light".
1. Recording at 96kHz/24bit yields greatly increased audio resolution-over 250 times that at 48kHz/16.
2. Recording at 96kHz/24 bit takes up roughly 3 1/4 times the space than recording at 48kHz/16.
Originally Posted by marvinfinnley
One other thing: it seems that one needs at least a master's degree to master the remote control. I have never seen such a complex unit. Even after carefully reading the manual for the functions I use, I still had problems at first. Now, after two months, I seem to be getting the "hang" of it.
Although it takes a little getting used to using the 2809 remote, IMHO using the basic commands of the 2809 remote is much more intuitive then having to figure out which button on which side of the 1909 you have to use. And as you say, once you've used it for awhile it starts making more sense. For tips on using the System Call feature you can read more here.
