Common problem. This is caused by a combination of Dynamic EQ (which boost the surrounds to maintain immersion) and the way TV audio is mixed (badly). I even have a section of my FAQ about "surrounds are too loud!": http://batpigworld.com/fadq.html#audyssey
Dynamic EQ is designed to work with films, which are mixed at a specific reference level. Audyssey MultEQ calibrates your volume dial so that "0" on the master volume corresponds to this reference, and the lower you drop the volume, the more Dynamic EQ kicks in to restore the perceptual balance of tone (bass/treble) and surround immersion.
The problem is that non-film content (TV, music, etc) is not mixed to any specific industry-wide reference, so it's difficult to know where the volume "should" be and Dynamic EQ may end up overcompensating. This is what you are experiencing. It's likely that the folks who mix the audio for football games "goose" the crowd noise in the surrounds to make it sound immersive and engaging for the typical junky HTIB speaker systems that most folks are using at home. You will get all sorts of issues like this with TV programming, bloated bass, overcooked surrounds, etc.
On receivers newer than your 2809, a new setting called "Reference Level Offset" was introduced to allow you to tone down how aggressively Dynamic EQ does its business. On your receiver, the workaround is to trim down the input source level for your cable/sat box input. In the Input Setup menu you can go down to "Source Level" and trim it down by up to 12dB. By trimming down the input source level, that forces you to turn the volume up more to get the same "loudness", and thus tricks Dynamic EQ into not boosting as much. This input level trick can also be used to tame boomy bass with music and other non-film sources.
The other option is simply to turn off Dynamic EQ when it gets annoying.
and I tried other options I have except resting the microprocessor.
just can't justify it right now with the home upgrades.
