AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Please help! Sony 40V4100 or Samsung 4081F
post #1 of 14
hello guys,
this will be my first lcd / big screen tv. been waiting / researching for a long time and im down to these 2 tvs. viewing distance is around 7 feet. which one should i get? i can buy them for exactly the same price. i've tried searching the posts here about the 4081F but need more inputs. please help.
thanks
post #2 of 14
post #3 of 14
thanks. any input from 4081F owners?
post #4 of 14
anyone? i'm planning to get it tonight. please help. thanks
post #5 of 14
how much are you getting the sony for?bb has the 4081 for 1149
post #6 of 14
Didn't he say they are both the same price?
post #7 of 14
best buy is dumping its 81 models,they are cheaper than any online vendor,I just wanted to let the op know,like the v4100 is 1350 at bb right now and the 4081 is 1149.
its an outlet price.so if he was matching the normal priced 81s it would of been the same,with bb dumping these he can save 200 bucks
post #8 of 14
got the Samsung T4681 LED LCD yesterday from BB for $1499 plus tax, holly cow this LCD was almost $4,000 less than a year ago
post #9 of 14
yes, got it for that price. actually, bought the sony for $50 more. thanks
post #10 of 14
how is it so far? any issues with it like motion blur, bad viewing angle, etc?
post #11 of 14
Yep!you are right about the 40-81 and 3yrs intrest free no 46-81 can be found at BB I just picked the 40-81 up and had the salesman look for a 46-81 and it can't be ordered.
Sorry! I order this tv online and the 3 year intrest free was 3 mo.
I had to go back to the store I picked it up at and re-purchase the tv to get 3 years intrest free.
with 6 at home I need to be cheeeeeeeep!
post #12 of 14
easily the best picture I have ever seen on a LCD, the most purest blacks of any LCD on the market today the black bars at the top and bottom are pure black, as far a motion blur yea there is a little but its not intrusive at all, and the viewing angle is not so accurate sitting in a certain spot, but it is so minor its shouldn't bother u at all you would have to be so far off from the viewing angle that you would not be able to see the TV properly to even notice
post #13 of 14
redhorse, I think you are in a better position than me since you are buying from scratch.
I was dealing with a warranty replacement so I recommend you go for the samsung.
It's a better price (while I was getting the same price in my case).
post #14 of 14
thanks everyone. i ended up with 2 4081's just in case the other didn't push through. hehehe
