Originally Posted by sikemo
Completely off topic, but does anyone know how to get multi-channel audio out of a 2 channel PCM source? I have my receiver hooked up to a HTPC with HDMI audio out. Receiver works great with multi-channel sources... especially in the THX Cinema mode. However when I play my music, which is in FLAC format, I can only get stereo audio out of the receiver. None of the music sound fields are available. When I try to select a Pro Logic mode, it just shows "PCM" on the front of the receiver. Using XBMC if anyone is interested.
Does it show 2 channel input or MC PCM? It should tell you how many channels on the front of the display.... if 5.1, that would be the problem (i.e. stereo sent in a 5.1 wrapper, which would be surprising.)
