Originally Posted by
mantaraydesignÂ
I have a question for the SC-07. There is a feature called
SW Input Gain. Right now it is set to
+10dB. There is the other option to set it to
0dB.
Is everyone leaving the default setting which is
+10dB?
As described on page 94 of the manual, this is only useful when using the multi-channel analog inputs (the searcheable pdf of the user manual, available on Pioneer's site, is your friend!). If you're connected digitally, this setting has no effect for you.
mantaraydesignÂ
Yes, it is an authorized dealer. I just received it and now I am trying to use it. It is a 2 year warranty from U.S.
Then you should be good to go. Just make sure you keep that official receipt from the dealer, to prove you really bought an SC-07 in 2014, should you ever need service in the next two years.
mantaraydesignÂ
I am confused right now on how to play blu-ray movies with the original sound track like DTS-HD Master Audio. The remote is quite confusing. How do I select the original sound format like DTS-HD Master Audio? Which button on the remote control do I select to get DTS-HD Master Audio while watch a blu-ray movie?
Which audio track is played is controlled by the Blu-ray player and the disc. Go into the movie's audio setup menu and select the audio track you want. If the player decodes internally, you will see "PCM" on the AVR. If the player sends bitstream, you should see the format name (DTS / DD /... ) on the AVR.
Hope this helps a little.
Dan.
