I will be getting an Integra DTR-7.9 in the next week or so. I just got it on order yesterday. If any one is interested I will put a full review up for your pleaser.
Amplifier
• 130 Watts/Channel (2ch Driven) @ 8 ohms (FTC)
• 180 Watts/Channel @ 6 ohms (IEC)
• 180 Watts/Channel @ 6 ohms (JEITA)
• WRAT-Wide Range Amplifier Technology
(5 Hz-100 kHz bandwidth)
• Linear Optimum Gain Volume Circuitry
• Push-Pull Amplifier Design with 3-Step Inverted Darlington
Circuitry
• H.C.P.S. (High Current Power Supply) Massive High
Power Transformer
Processing
• THX Ultra2 Plus*1 Certified
• HDMI Video Upscaling (to 1080p Compatible) with
Faroudja DCDi Cinema Enhancement
• HDMI ver.1.3a with Repeater System (Deep Color,
x.v.Color, Lip Sync, DTS*2-HD Master Audio,
DTS-HD High Resolusion Audio, Dolby TrueHD*3,
Dolby Digital Plus, SA-CD and Multi-CH PCM)
• Component Video Upconversion
• Non-Scaling Configuration
• Direct Mode
• 192 kHz/24-bit D/A Converters
• Two TI (Aureus) 32-bit DSP Processing
Connections
• 5 HDMI*4 Inputs and 1 Output (ver. 1.3a)
• Onkyo for System Control
• 6 Digital Inputs (3 Optical / 3 Coaxial)/2 Output
(1 Optical/1 Coaxial)
• 5 S-Video Inputs / 2 Outputs
• Component Video Switching (3 Inputs/2 Output)
• Banana Plug-Compatible Speaker Posts
• Powered Zone 2 and Zone 2 Pre Out
• IR Input/Output and 12 V Trigger
• RS232 Port for Interface Control
• Bi-Amp Connectable for FL/FR with SBL/SBR
Miscellaneous
• SIRIUS Ready*5 / XM Ready*6 with XMHD Surround
(North American models only)
• 40 SIRIUS/XM/AM/FM Presets (North American
models)40 AM/FM Presets (Australian model)
• Audyssey MultEQ*7 Room Correction and Speaker
Calibration
• Audyssey Dynamic EQ*7 Loudness Correction
• Crossover Adjustment
(40/45/50/55/60/70/80/90/100/110/120/130/150/200 Hz)
• A/V Sync Control Function (up to 250 ms)
• Music Optimizer*8 for Compressed Music
• Newly Designed GUI for System Set-up
• Compatible with RI Dock for iPod
• Aluminum Front Panel
• Preprogrammed
Amplifier
Circuitry
Power Transformer
Processing
• Direct Mode
Connections
Miscellaneous
Calibration
• Preprogrammed
