Apologies in advance that this topic has been touched on before in numerous threads. However, I haven't seen what I would consider to be a straight answer.
For an office application, I am planning on storing a 50-52" panel (plasma or LCD) in a swing-down ceiling-mounted lift--i.e., the panel is stored flat most of the time).
(If you have any views for LCDs to the extent that the answers differ from those for plasmas, I would be grateful.)
Thanks in advance
Bongo
- Does this pose any problem for plasma in terms of (a) total failure; (b) performance; (c) useful life?
- Are there any issues with powering on the plasma immediately after swinging it down, or swinging it up immediately after powering it off?
- If someone forgets to turn off the display prior to swinging it up, and it is powered while in a horizontal position, would that cause any problems?
Thanks in advance
Bongo
