AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Replacement lamp for Runco VX-1
post #1 of 2
Hi all,
I have a Runco VX-1 (actually the label reads 1-VX) that I removed from a customers home after upgrading it to a newer 1080p projector.
I am donating the projector to a local school and I need to replace the lamp.
I am a bit confused as to the correct lamp needed. It seems the Runco model is RUPA003600 but the original lamp I removed from the projector reads LT81/100 LAMP which is a NEC lamp.
Does Runco use NEC lamps or did they in the past? which lamp will work?
I just need some reassuring before I shell out $500
post #2 of 2
As I recall that was a rebadged NEC (though I don't fully remember). I believe an NEC lamp will work, but I cannot be sure if Runco modified it at all.
