I'm planning to move from cable to Directv in the few months.
I've enjoyed immensely the move from a VCR to this product.....Thanks Wajo for your "Bible" in laymans terms on using the Philips
I've seen the connection pictures, I have no problem with understanding those, I wanted to know from the user's angle. What issues should I be aware of, that I can or cannot do, with using these products together.
I do have a HDTV (Samsung LN40A530), I currently have extended basic cable (Analog) no cable box, not concerned with OTA at this time. I mostly record different shows on different channels to watch/delete & put on to DVD. I have a DPX-7000 Video-Enhancer.
As far as Directv goes my plans are to go HD with HD receiver, not sure if I should go with a HD/DVR & then transfer to my Philips and create DVD's, or trust the Philips to do the trick ???
From what I've read, the Directv Box won't change channels, so if I want to record 2 different programs on different channels I'll need to change manually or use a USB TV Translator ??
[url="http://www.patersontech.com/products/UsbTvTranslator.aspx"]
Thanks Again for the great resource of Information
Steve
Steve
I'm sure like Kelson pointed out, I probably be able to get a playoff highlight DVD, if I choose to.
I haven't gone from cable to D* yet.
