Originally Posted by
DevilDog151
Can any calibrators out there inform me on what all is required to fully calibrate a 5020? I'm still a little confused and after reading posts on the ControlCal forums that the only thing that can be adjusted is the grayscale. I'm trying to figure out if calibrating a 9G kuro warrants the same fee from a calibrator as doing another set with more calibrations unlocked in the service menu.
It all depends on what you mean by "fully" - there's no video display I know of that can be "fully" calibrated. Even a $4500 Lumagen Radiance XD video processor, as nearly perfect as it can make just about any video display, has some "holes" that, if filled, would lead to an even better calibration.
What can be done with the 5020 is extremely helpful... but the only adjustments accessible with special software (that the calibrator has to purchase and make up the cost of in calibration fees) are 2 controls that adjust the grayscale. However, done correctly, the 5020 calibration will make some of the primaries and secondaries more accurate even though there are no accessible controls for them - it's just a lucky break that seems to be pretty consistent. The 5020 (and 6020) are amazingly good after this calibration. As already mentioned, having fewer adjustments doesn't necessarily mean a faster calibration. Doing a good 5020/6020 calibration usually takes just about as long as a calibration for some other displays that have more controls. Calibration is the only way to get the 5020/6020 color temperature accurate since none of the modes are close enough to 6500K to not be making the image too warm or too cool.
