Although the component video and optical audio solution works to prevent STBs from spontaneously resetting their video resolution, this solution created another problem when I used component to connect my TiVo Series3 to my 3900. With component video, the screen would black out for a second or so every time a signal with a new resolution was received. That finally started to bug me so much that I changed back to HDMI and decided to live with using a 1080i Fixed resolution, instead of the Native, which I really preferred. I understand that there are HDMI switches that resolve the problem but they are rather expensive, so I decided not to even try one. I agree, though, that there is no practical difference between the PQ of an STB's video with component compared to HDMI.
post #4231 of 5994
12/13/09 at 6:51am
- gwsat
- Trader Feedback: 0
- offline
- 12,649 Posts. Joined 5/2004
- Thumbs Up: 40
- Select All Posts By This User
I do really like my 1900, sans the small volume display
