AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" RX-V1900/RX-V3900 Thread
"Official" RX-V1900/RX-V3900 Thread - Page 143
post #4261 of 5994
Originally Posted by LCP1 View Post
It should, or at least it was implied in the service manual (I would say maybe half of the world's 1900 are without USB ports, and the other half have USBs, but they seemed to share firmwares). So, any luck in getting the firmware in .wav format, I'll be a willing beta tester too!
I still don't have a 1900 .wav file, I was just hoping there would be one released to match the 1.09 firmware for the 3900.
As for loading the .wav firmware into a 1900 with a USB port, I guess the first test (if we ever see a .wav file) is just to try doing the update with the standard version. I'm just a little unsure it will work because USB support on the 1900 was done by including almost the entire network module from the 3800 (yes 3800, not 3900). So it would the same as loading 1800 firmware from CD into a 3800. It might work.
post #4262 of 5994
I don't know if this topic has been resolved here or not but I found a way to stream both pandora and spotify to my 3900. I have been using a program called Jamcast Server. It installs on my laptop and uses a virtual sound card to stream to the 3900. It is working great!!!
Here is the link for Jamcast: http://www.sdstechnologies.com/
By the way it also allows me to stream to my PS3!
post #4263 of 5994
I also downloaded and installed Jamcast. Painless. Works perfectly so far. I might say goodbye to my Rhapsody subscription.
post #4264 of 5994
Michael,
I just noticed today that they have a new release out. I didn't know if you saw it.
post #4265 of 5994
No. I just installed it within the last 7 days. And I have not tested it extensively, as I was mainly interested in streaming Pandora, which is does very well.
post #4266 of 5994
The new version was released on 12/16/2009.
post #4267 of 5994
Originally Posted by mr_sonus View Post
How do you delete the account? Where would I find this option?
AVR Main menu>Music Content>Rhapsody>Submenu
You'll see "Delete Account" there!
Cheers
post #4268 of 5994
Hi everyone,
I just got the RX V1900 open box special from Best Buy for $600. I bought the denon 32808ci for $699 and didn't care for it so I got this instead. Was going to get the 863 for $450. Is this much better or worth the extra $150? I need a remote and calabration mic but can probably get both for under $50. Anyone have any links? I'm upgrading from a 9 year old Pioneer VSX 510 so I guess a hampster wheel would sound better. Also, is there a firmware update for this and if so what does it correct?
Tony
post #4269 of 5994
Originally Posted by tjarmusz View Post
Hi everyone,
Tony
Worth the extra $150 over the 863? Hell yes, IMO. The 1900 has the same analog audio circuitry as the 3900 and Z7 and the same power supply.
I am not sure what a remote and mic will run you. I suggest contacting Yamaha support to get those. I am not convinced the mics used by Yamaha receivers are all identical; if they are, any one will do.
Even if they cost you $100, I still think it's a good deal. If they did not give you the manual, you can download it.
Out of curiosity, if you find out the price on the remote and mic, I would be interested in knowing what it is. You can message me.
post #4270 of 5994
Just found remote, mic and antenna here:
http://www.newremotecontrol.com/cata...d8b25c81aebfb9
post #4271 of 5994
Looks like you are set. I think you will be happy if the open box receiver was not abused. They are built pretty well.
post #4272 of 5994
Anyone know if there is a firmware update for the 1900?
post #4273 of 5994
Did you search this thread? Should be a mention if there was one.
post #4274 of 5994
There isn't one on the Yamaha site.
Click on the link below, sign up for a free account and search for RX-V1900. There you will find a manual and other info.
Yamaha
post #4275 of 5994
If I have the 1900 hooked up via hdmi from my blue ray player then I should use bitstream because the reciever can decode everything and send it out to 5.1 right?
post #4276 of 5994
You can do that, yep. You won't get secondary audio ability, but most people don't seem to care about that.
post #4277 of 5994
I use bitstream with my 1800. For one thing it means you can just glance at the receiver's display and see what the format is (TrueHD, DTS-HD MA etc.). And with decoding and post-processing happening in the same place there's less to go wrong (in most cases nothing goes wrong with player decoding anyway, although some players might not have a full featured decoder).
But if you want to hear secondary audio (e.g. Director's commentary), then you have to switch back to decoding in the player. So some people leave it like that.
post #4278 of 5994
I just hooked up the 1900 and have no sound from the sub at all. The volume is turned all the way up on the sub and and I am not running in pure direct or whatever its called. I have the correct preout selected and my sub and cable are fine.
My sub is old and only has volume control so that might be an issue. Also I don't have a remote (open box special) so I can adjust the settings or run ypao. I'm getting a Bic100 tomorrow and wondering if this will help as I heard the subs needs a lot of juice on the yammys.
For now I hooked the sub up to the center channel input and I get ok, somewhat localized bass. I'll post more when I get the h100 hooked up, but does anyone have any thoughts on this? Could the input be damaged or defective or do I just need to get the remote and adjust some settings? Is there an alternate way to run the sub besides through the center channel input if the preout is defective?
post #4279 of 5994
If you haven't configured anything (because you have no remote), then I think the front speakers default to LARGE. This means you'll get no subwoofer output from a stereo source, such as a CD, so what you're hearing could be normal. You need to change the speakers to SMALL to get bass redirected to the sub. I don't know if there's a way to do that with the front panel controls only.
post #4280 of 5994
Thanks, i'm ordering the remote so will post an update in a few days. I think it will solve this issue as my set up is the engery take 5's which are small. Still even with large fronts, wouldn't you want a sub?
post #4281 of 5994
Hi Michael!
I must be missing something. I set up Pandora and it works fine on my PC. On my 3900, I can see the shared folder that Pandora is sharing, but I can't figure out how to stream the customized 'radio' stations that I have set up in Pandora. Do you have any idea what I need to do to fix this?
Thanks again, and Happy Holidays to you and everyone else here!!!
post #4282 of 5994
Originally Posted by ira_l View Post
Hi Michael!
I assume you installed Jamcast? If not, you need to do so. You then goto iJamcast on your 3900, and select playlist, and then virtual soundcard.
post #4283 of 5994
Yes, I installed Jamcast. Where do you see 'iJamcast' on the 3900? Thanks again!
post #4284 of 5994
I've joined the RX-V3900 club,
It's available via Google searches around £969- £999, I couldn't resist, it was a tossup between a RX-V1900/ 1065/ Onkyo SR707 or Onkyo SR807.
My trusted 11 year old Yamaha DSP-A2 gets mothballed and my new 3900 will be taking it's place. I have to say it is still not cheap but after many years of A2 pleasure with it's full rich well defined sound field I'm looking forward to this baby.....
Q1: how do I check firmware version?
thx for any replies guys.
post #4285 of 5994
It should show up as a server under the music content menu; network music (I forget the exact name.)
post #4286 of 5994
Newbie question:
The Yamaha 6290 (aka 1900) seems to have higher level power specs, but does the Denon 890 have better video upconversion than the Yamaha?
Price difference between these two is going to be minimal in an upcoming sale (bigger discount on the Yamaha) - is there an obvious choice between these two?
http://www.avsforum.com/avs-vb/showthread.php?t=1181784
post #4287 of 5994
Originally Posted by googlefish View Post
Newbie question:
The Yamaha 6290 (aka 1900) seems to have higher level power specs, but does the Denon have better video upconversion than the Yamaha?
Hi.
What model Denon are you comparing to?
And is a 6290 really a 1900? I'm sure aside from a badge and colour, these two do share some differences...
I may be wrong though..
post #4288 of 5994
It shares the 1700 firmware I think?
It's lighter than the 1700 by a bit. It's power consumption is the same at 500 watts. No max is listed on the 6090; the 1700's max is listed at over 1000 watts.
post #4289 of 5994
Lighter and same power? Interesting.
Out of curiosity I'd love to read the maximum power consumption figure that's written on the back of each or them.
post #4290 of 5994
I would guess it's the 500 watt figure in the manual. I wonder if the max is inrush current only when charging caps, or what?
