AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" RX-V1900/RX-V3900 Thread
"Official" RX-V1900/RX-V3900 Thread - Page 178
post #5311 of 5994
Originally Posted by andrewdoan View Post
I manually change the EQ set up from PEG to GED and amazingly there is a tremendous amount of tame down on the brightness and up front image.
The defaults for GEQ are flat (no adjustments to any frequency band), so it just means that YPAO set the PEQ filters to make your system sound brighter than you like. I'd recommend that anyone compare YPAO on and off after running it, because it doesn't always make things sound better. But you should also turn it back on and compare the three modes (Natural, Front and Flat), to see if you like any of them.
post #5312 of 5994
Originally Posted by davecn View Post
...Yamaha works in mysterious (some would say slack) ways methinks...
I'd agree with that! But usually anyone who has access to the firmare can get the corresponding document that describes the changes made in that version. So maybe they can dig that up for you.
post #5313 of 5994
Now I know why I liked the Yamaha 1900 before setting up the YAO and then had problem with the "forward" and "harsh" HF after setting up the YAO.
post #5314 of 5994
Just a heads up for anyone flashing firmware 1.13!
I did experience a problem with the hdmi switching from my ps3 after the flash. the 3900 would not display the ps3 if i just switched to the input, i had to leave it on that input and then cycle the 3900's master/main on/off switch, when it came back on it would show the ps3 picture.
I just reverted back to 1.11 by renaming the bin file to a number higher than the 1.13 version and everything else is fine now..
post #5315 of 5994
+1. With the current closed out deal of the 1900/3900, there is no doubt that's the best bargain/ value outhere.
Yamaha owner, please help. What's speakers in your bias/ unbias opinion will mate well with the 1900/300 without giving the fatigue listening for 2 channel listening either HD radio or Internet radio?
I have achieved very good results with a Paradigm Studio setup.
post #5316 of 5994
Yes, I've requested it and they have now sent it to me so I'm pleased about that as I now know what was updated.
post #5317 of 5994
Davecn,
could you post the document or its contents on what they changed/updated?
post #5318 of 5994
Originally Posted by race1 View Post
Davecn,
Already sent
Cheers
post #5319 of 5994
It's probably good practice to make sure all HDMI connected devices are switched off at their power supply when doing updates on the receiver.
Actually, I've had problems similar to yours previously and from my experience it causes a problem with the HDMI cable. Switching to a spare cable seems to fix the problem each time. Not sure why??
On a separate note, I moved back to Sydney from Macau 6 weeks ago and I'm still waiting for my RX-V3900 to get here (along with speakers and the rest of our items). Should be any day now............please!!!!
post #5320 of 5994
There's no harm in posting it here in this thread for everyone to see, I'm sure quite a few will be interested.
post #5321 of 5994
Service News
Audio
YAMAHA CORPORATION
P.O. BOX 1, HAMAMATSU, JAPAN
BULLETIN
NO. E-1368
RX-V3900
RX-Z7/DSP-Z7
DATE: July 2010
RELATED
BULLETIN NO.:
F/W Update re: Intermittent Audio
SYMPTOM:
1. In some case during BD disc playback, intermittent audio is output while decoding Dolby Digital.
2. In some case during MP3 music playback with USB drive, less than a second of music is cut off in the beginning.
3. Under certain setting, pop noise is output when switching DSP programs.
SOLUTION: Update to the latest firmware as shown below. Download the data from Yamaha AV
Service Information Support System website / ROM Update RX-V3900 or RX-Z7/DSP-Z7.
Advanced Setup Mode Version: 1.13
DIAG mode Version Checksum
VNP2(VIDEO) S.0101.0180 EDC140BA
M32C(MAIN) S107 D274
DSP1 05.00r -
DSP2 03.00r -
D-SUM - 3d8c8339
SERVICING: Update the firmware when brought in for service.
had problem no. 2 with 1.08, now fixed.
post #5322 of 5994
Is it worth to sell the RXV 1900 at a loss to buy the RXV 3900? What will I achieve in doing so?
post #5323 of 5994
See the RX-V1900/3900 thread where I explain this in detail (I think I do.)
Short answer - video. The 1900 has the plain GUI, and lacks the ABT video processor. It can't convert HDMI video as memory serves.
post #5324 of 5994
Not to derail current conversations, but I wanted to follow-up with my experiences in my attempt to utilize the 12V trigger for speaker switching with a Niles SPK-1.
I confirmed today with Yamaha that the RX-V1900 (and 3900, I assume) only outputs 15mA on the 12V trigger. This is insufficient current to switch the Niles SPK-1, which requires 100mA.
Now I'm considering building a low-voltage relay box that senses the 15mA signal from the Yammy, in turn switching the current from a 12V wall wart to activate the SPK-1 (something like this). What a pain in the rear!
Anyways, just a heads up for anyone thinking they can use those 12V triggers to activate anything requiring a bit of power. You only get 15mA.
post #5325 of 5994
Interesting. I purchased an RS-232 to USB cable in order to enable the trigger out on the 1900 I recently purchased as I had read in previous posts in this thread that it may not be enabled by default. To my surprise, when I hooked it up to my Emotiva UPA-7, it triggered it on the immediately and powers it off as expected.
While this isn't the same scenario as your configuration, I wanted to mention it in case others purchase the 232 to USB cable for this specific purpose, I'd just forgot to mention it until now... -TD
post #5326 of 5994
I picked up an RS-232 to USB cable for programming via the Receiver Manager program, which is how I intended to control the activation of the 12V triggers by source. This seems to work great. I can set all the sources to low (no trigger signal) except for the CD and Phono inputs. Like you, I found the triggers were defaulted to "High" or "On".
The issue here is that the SPK-1 uses the 12V signal to power the relays inside the box. It's not simply "sensing" a signal, which is what your Emotiva does. Niles makes a powered sensing switch, the SAS-1, but even that requires a 20mA signal. I may try it anyway and hope the tolerance stacks on both ends of the signal path are close enough that the switch will function with a 15mA signal. I'm running out of options... so much time and expense so I don't have to physically push a button
post #5327 of 5994
Can this receiver pass 3D with a firmware update?
post #5328 of 5994
It possibly could, but I'm sure we won't see such an update from Yamaha.
post #5329 of 5994
I am quite happy with my 1900 now after I have every EQ manually set up to flat .
The Yamaha web-site and I believe the 1900 manual did mention that the 1900 has the ABT chip. Can you clarify it for me? If not, what video chip does it has ?
post #5330 of 5994
The 1900 uses the ABT 1010 video scaler which is nothing special. The 3900 uses the ABT 2010 which is much better, but I don't count on my receiver to do scaling (I have the 1800 which is almost identical internally to the 1900). I try not to watch SD TV or even DVD any more, but for DVD it's not hard to find a player that scales well, so the receiver doesn't have to.
post #5331 of 5994
Thank you for the clarification. So, if I use only Bluray disc, there will be no difference between the 1900 vs the 3900?
post #5332 of 5994
The 3900 has the option to do some processing of HDMI video (although not as many options as the Z7), but normally you would want that turned off so it passes the Blu-ray player output untouched. In that case it will be identical to the 1900 output.
post #5333 of 5994
Not quite. The 3900 has network audio, I don't think the 1900 does.
And the 3900 can overlay volume display over HDMI. I don't believe the 1900 can.
post #5334 of 5994
I think we were just talking about video picture quality (or at least I was). The 3900 does have quite a few other non-video features that the 1900 doesn't.
post #5335 of 5994
I have a HP net book and a USB/ Optical converter from Turtle Beach, so the net work feature of the 3900 does not appeal to me .I am only interested in the audio/video quality of the the 1900 vs the 3900 to justify for me to sell my 1900 to buy the 3900. All the fancy DSP mode is nice to have but I rarely used them in the past even with my long gone DSAP1.
post #5336 of 5994
ok ok, keep your 1900 then
post #5337 of 5994
The last person I have sent the 1.13 FW to now is: bskultety
post #5338 of 5994
i second the keep the 1900 as well.
I'm very happy with mine. There are some features that are missing from the 1900 that the 3900 adds. but in the end I found the 3900 just wasn't worth it.
Things that the 3900 adds would be...
HDMI pass through while in standby (note it also adds 30 or so watts of power use)
xover frequency adjust for each channel (front, side, rear, center...)
Like I said before a page or two back: I'm very happy with the 1900.
post #5339 of 5994
My measurements put it at more than twice that. Keeping the web server running does the same. I wonder if the A3000 does the same?
post #5340 of 5994
The new models are more efficient. The A3000 doc says 2.7W with HDMI Standby Through On, and 4.5W with NET Standby On.
