Originally Posted by
stevethebrain
I personalley would like to see two displays first for regular volume second for potensionale volume you know when all of a sudden you get blasted w/ effects sound. best I can explain this is like when a explosion or car crash ect. happens the volume like doubles.
Well... I'm sorry, I'm still not sure what you wanna see. What does the car crash has to do with the volume bar? The volume bar has always the same black background.
stevethebrain
couple more ?s
1.I've read that the RXA1000 has a substandard FM reciever is this true or false?
2.what quailifies a amp. as clean power? the rate of distrotion?
3.I'm still confussed on why some Yamahas have BL on the end of there model #. Kirk thought it could stand for color being black however New Egg has models listed w/ the BL on model # then list the unit as a Walnut color (whatever walnut is)?
NE also lists other units color as black w/ the BL as part of the model #. I'm thinking BL stands for not first rate product w/ a minor blemish.
4.w/ a 7.1 Yamaha amp. is it more designed for front present speakers than wides?
Thanks STB
1. I don't use it, so I can't tell you. Maybe someone else.
2. Several specifications may be related with "clean power", but manufacturers don't always publish the complete specifications, and sometimes they even twist them a little bit to make their products more attractive. Don't get too obsessed about specifications. Having that said, rated distortion may be an indication of "how clean the power is". But in order to compare products of different manufacturers you'd need to have the exact same test condition - number of channels, output power per channel, frequency (or white noise), etc.. They don't always perform these tests in the same conditions either.
3. BL means black (SI means silver). Someone at the Egg wasn't paying ANY attention...
4. Again, not sure what you mean by "more designed". But anyway, the RX-A1000 supports only "front presence" speakers - although, of course, you may want to try placing your speakers in a different position and see the results.
One more thing... you should probably ask about the A1000 in its own thread (the one that has the picture of the volume bar). Otherwise the moderators will get mad at us both.
VMat
