Correct. I contacted Yamaha about this as well. They stated that the chip to overlay the volume indicator over HDMI, if added to the system would make it prohibitively expensive to produce, given the current price range.
My wife doesn't like the fact that we lost our OSD for volume either. If the 3900 could do it, I'd switch. Actually, she might even make me switch. haha
According to their email though, I think the 3900 may have it.
Here is their actual email response to me, and my original email. This is from when I was looking to upgrade my 2500 to a 2700, which I ended up doing, for the HDMI:
Brian,
Right now, none of our receivers have the capability to over lay the volume control information on an HD signal. In order to do so the receiver would have to have a digital video upscaler. That technology is not available on any receivers in that price range at this time. You are probably looking at the next generation at least until that feature will be added.
Best Regards,
The Yamaha Customer Support Team
Receivers [AV and Stereo]
Model: RX-V2500
I have an RX-V2500 that I just connected to a new Sony TV via component video.
I have found that the OSD (volume display, and sound field program) do not display over the video, especially since I'm at 1080i. I've looked online and this is apparently just by design.
Does the RX-V2700 display information over component at 1080i? This seems to be a bit of a design flaw if not... would future models have it if the 2700 does not? Since all tv's are moving to component or hdmi, it would seem having OSD would be important for volume information..
Brian,
Best Regards,
Model: RX-V2500
Maybe there would otherwise be 100 angry posts. Maybe it clips 0-255
