AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Samsung BD-2550/BD-P2500 Master Thread
Samsung BD-2550/BD-P2500 Master Thread - Page 65
post #1921 of 7056
Originally Posted by Bladerunner1959 View Post
That is all a fair question, I did intend to tie it together since the 1200 is an hqv machine as well and similar to the 2500. I love the Samsung video quality on bluray and on standard dvd as well. After 1 challenging year with the 1200 , I am too gun-shy about the (IMHO) the lack of speed with FW upgrades, I dont wanna lose the benefits of the hqv with std dvd via a FW upgrades as that did happen on the 1200. Std dvd was noticeably better when I 1st got the unit BUT...after the 2nd FW upgrade was done it hit me that I was losing something. Trust me, I am(was) temped to float one of these on plastic for more comparison as well.
For the 2500, I have seen more posts about blu and std disks not playing back properly compared to the other machines. I have not had 1 pause freeze or no-play with these 2 machines yet and I have thrown everything at them except Bond on blu that I need to go rent today.
If I'm reading your post correctly, you're concerned about losing the ability of the HQV processor to continue to upscale by FW updates? I can't see FW updates keeping this from happening. The 2500/2550 have the HQV Reon Processor, and they upscale beautifully, so you wouldn't have to worry about losing that feature by moving up. Like I've stated, I went through all these problems with my previous players and beat my head against the wall but I am extremely happy with the 2550. Having an AVR that decodes is going to make it that much better if you can achieve that. If I'm missing your point about the processor, please correct me.
post #1922 of 7056
Originally Posted by wobbegong View Post
I said:
It occurs to me that the activation code might be a mechanism to restrict Netflix streaming to one player per Netflix account. Can any of you who have more than one 2550 state whether you can stream to multiple players from the same account? (Just curious.)
Netflix definitely tracks how many devices are currently activated to your account. According to netflix.com my account can accomodate up to 6 unique devices (including computers and Netflix ready devices such as a Samsung BDP).
post #1923 of 7056
Originally Posted by n517rv View Post
FWIW I purchased a 2550 at BB less than a week ago. I have yet to get Netflix to work at all after about 2-3 firmware upgrades since I purchased the unit. The error I get tells me that Netflix "cannot connect to your home network". That's a bunch of bull because all other network connectivity works fine. I've done firmware updates via the network as well as Pandora and both work great.
HappyFunBoater's suggestion of turning off DHCP and manually setting DNS primary and secondary did NOT work for me.
IMO, this is all a bit ridiculous... when are Samsung and Netflix going to get this figured out? I most certainly don't have any connectivity issues on my home network. The issue appears to be a problem with the Netflix portion of the firmware update, although it may be an issue with the Samsung/Netflix server as already suggested previously in the forum.
Come on Samsung/Netflix... get this figured out!!! Has anyone there heard of the Alpha/Beta testing process for quality control? Or, maybe we're all Alpha testers and we just don't know it.
On the brighter side Pandora is really neat and has worked flawlessly. I didn't even know what Pandora was until I started researching which Blu-Ray player buy and came across the 2550 offered by Best Buy. If you're a music fan definitely check out Pandora.
I'm certainly glad I bought the 2550, but would REALLY be happy with it if Netflix would work on it.
One more note, last night (1/1/2009) I turned my unit on and it wanted to update to the latest firmware. I let it update and it installed 2.3 (referenced as 081230.01_091108BL_1254.08_XAA). Not sure why, but everytime I've done firmware update over the network when I reboots it says a new firmware update is available and wants to redo the whole download and update process. This is really annoying as it takes twice as long. Today I registered my product and logged into the Samsung website. I copied the USB version of 2.3 and let the 2550 update off of the USB drive. I like this a lot better than the network updates. Seems to be faster and it didn't try to install twice like the network update. I'll probably stick to USB updates in the future for this very reason.
I had a similar issue with NetFlix not working. I discovered that when the Netflix portion is launched the 2500 sends a ping to the default gateway (router) on your local network. If that device blocks ICMP (Ping) then Netflix will fail. The device will be able to update firmware and get time via NTP. It only appears to affect the NetFlix portion. Many routers allow you to block ICMP in the advance network settings. Hope that saves someone the two hours I spent on it.
post #1924 of 7056
FYI, this FAQ link: http://www.netflix.com/FAQ?p_faqid=2902 outlines the Netflix "Watch Now" limitations.
Up to 6 devices can be authorized, but you can manage the devices; i.e., de-auth one to enable another to have access.
The number of simultaneous streams you can watch depends on the plan you have.
I have 2 HD TiVos and 2 BD-P2500 authorized and have seen no major issues with any of the devices.
post #1925 of 7056
Originally Posted by kirbalo View Post
You know this is illegal, against FCC rules, and federal regulations...right? They cannot tell you that you cannot have a dish...
Look it up. Federal Law "trumps" all local administrative rules.
I'm not certain but I believe that only applies to OTA antennas that may be needed for the digital conversion coming up.
post #1926 of 7056
Originally Posted by WRX_Rocky View Post
Timmarfil, I hate to say this, but it IS now time (for you and others) to upgrade your receiver.............Remember, your AVR is NOT some old antique Ferrari that is worth spending money on to keep running. And with the cost of very decent AVR's (see below) being not that expensive, there is no excuse to not upgrade now.
Unfortunately, that is the decision I reluctantly have come to also. This does miss the point though that the 2550 was supposed to 1 of only 2 or 3 BD players available that could decode the lossless sound tracks and pass them through the analog outputs. It's disappointing to spend time researching brands and models, make what you think is a sound $500 buying decision and then find out you were wrong. My 4 year old H/K may not be a Farrari but it is a very capable analog amplifer that would have been up to the task if the 2550 delivered on it's stated feature set.
When you look at the marketing side of this, some manufacturers are putting analog outputs on their higher end players because they know there is a segment of the market that desires that feature and they are willing to pay a price for it. Not implementing that feature properly is inexcuseble. That said, once I lick my wounds and buy an HDMI receiver, I will forget all about this and love the picture on my 2550 but will probably never buy Samsung again.
post #1927 of 7056
I have the same feelings about the shortcomings of the 2550. While I think Netflix is great... I use Blockbuster and Pandora is cool, but has something more to be desired from. Now, that DTS-HD MA is not supported, I wouldn't hesitate to take my 2550 back to BB and get the Panasonic 55 if I could "find it" and for $350. With the 55 I'd get DTS-HD MA, a SD Card reader for camera pics, and a lot more supported disk types which might include playing the Bluray Pixar's Short Films Collection, which only my machine won't play.
post #1928 of 7056
Originally Posted by Meathammer View Post
I believe that is the firmware version that was on my Sammy until I flashed it with the 2.1 version last night.
Now to test it this weekend and see if I'm still having freezing issues. If so, back it goes.
You say you updated to the latest FW, and referred to it as 2.1. I just replaced a defective unit I rec'd for Christmas yesterday, and have updated (via USB - BTW, put the FW unzipped, RUF, at the root of the USB drive). The unit was at 081017_02_BDP2550.xaa when opened, and I've updated to 081126. I know Samsung said we were getting an update 12.31.08 (which was supposed to include MA), but when I search for the bd-p2550 fw on Samsung site, there is none (current), however, there is a v2.3. for the bd-p2550. I've read here that the 2550 and 2550 FW is the same. Can I get a confirm on this, and also, how does one tell that the FW is 2.1 vs 2.3?
Thanks, kids!
post #1929 of 7056
OK, So I have a home theater and everything is hooked up to my Onkyo TX-SR806 receiver. All my other equipment works fine with the receiver via HDMI hookup.
So here's what's happening with the Samsung BD-P2500 and my Onkyo TX-SR806:
When I turn on the bluray the receiver is still capable of being operated by the remote, but as soon as the bluray disc loads and displays the disc menu, the receiver ceases to accept any remote control commands. I try to change the volume and the receiver does nothing. I try to change the receiver input with the remote and nothing happens. The only way to control the receiver is manually by pressing buttons on the front panel or turn the volume knob. As soon as I turn the bluray player OFF, the receiver then accepts remote commands as normal.
I have tried to change some settings on the Samsung to see if they were the cause and I have had no luck.
Does anyone know why this is happening? Is this just a setting I have incorrect? Is this a function of the particular Disc I am playing?
I updated the Samsung firmware today which is the first day I have had the unit. I did not try the bluray before I updated the firmware so I do not know if this is a result of the new firmware.
Any help would be appreciated.
post #1930 of 7056
Not sure where exactly the problem arises. I have a DISH DVR and Samsung 2500 Blu Ray player hooked up to the Pioneer THX 01 AVR, both by HDMI cables.
If I am watching a movie on the Samsung 2500 and PAUSE the movie to go over and watch TV then the video and audio work fine in watching TV from the DISH DVR. But then if I switch back to the Samsung 2500 Blu Ray player to resume watching the DVD, I get Video but no Audio at all. Funny thing I found out by trial and error is that if I push PLAY on the Samsung (that was on pause) right before I switch the Pioneer 01 AVR back to the Samsung 2500 then all works fine on the audio.
Bottom line is that if I switch the Pioneer 01 AVR over to the Samsung 2500 that was on Pause, then I have no audio working once I push Play again on the Samsung. So which is the culprit? Since the Audio works on the DISH DVR when switched over then I would think it is a Samsung problem but not sure.
post #1931 of 7056
I can relate to that point. I have a nice Outlaw 990 pre-pro and it's going nowhere. There is no need to discard a perfectly good receiver for a new codec that may or may not bring more listening enjoyment.
A lot of BD have Dolby TrueHD or LPCM, which the 2550 will do. For the few remaining discs that have DTS-HD MA, you could always listen to the regular DTS track? It's not like DTS is total garbage! It was the best money could by on DVDs and you weren't hearing people complain about DTS then...
My 0.02
post #1932 of 7056
I'm somewhat amused (again!). As of right now (1/3/2008 @ 8pm Centrel) Samsung has the new 2.3 FW available for download in the BD-P2500 section. Head into the download center for the 2550, and no downloads are available ............... yet mine is pulling the FW over the wire right now
I tried the 2500 for giggles, and it of course immediatly failed. Sure wish I'd kept the previous revision RUF file around so I could compare the two.
I also with Samsung would put a friggen readme/change log on these, unless I'm missing that? It's always a mystery what they've added / fixed to me.
post #1933 of 7056
It's already been discussed in this thread how you retrieve the 2550 update on the Samsung site. It's there, just not in the place you're looking. Samsung made it obvious to many of us that you're not going to get the update via the site unless you register your player with them first. Probably due to the fact that the 2500 does not have Pandora and they don't want people with 2500's downloading the FW for the 2550 that does have Pandora. My 2550 updated perfectly via burned disk, but I wouldn't be sure that both FW are identical.
As far as the fix, it's typically addressing playback and compatibility issues with some disks and that is the default reason. Personally, I could care less "what" disks they're addressing as long as every disk I play works.
post #1934 of 7056
Originally Posted by EDH63 View Post
As I've always said, it's best to burn these updates to disk or load them to a zip drive so you can have them later. Since Samsung is no longer referencing older updates on their site, I would recommend you call them and have them mail you the 2.1 version. Although, I heard recently Samsung will not send you a non-current FW disk. I'd call anyway and see for yourself.
I've got the Onkyo 705 and the normal listening volume level when I have movie nights is 70 and it sounds fantastic. I want it to be like I'm at the theater. I watched 'Traitor" last night in TRU-HD and it rocked the house. TIHII was another one, in DTS-HD MSTR, that sounded fantastic. The bass was phenominal and I'm only using a 10" sub. I have no distortion and the AVR never shuts down. I do have a small fan set atop my AVR that pulls excess heat out of the box, so that helps. I ran Audessy and calibrated my speakers for my room and then tweaked it from there and that made a huge improvement. All of that to say that you should be able to crank it and not have your system shut down.
I can't go into detail about your receiver but I would recommend that you get into the "Audio Area" http://www.avsforum.com/avs-vb/forumdisplay.php?f=90, find the 606 thread and talk about this there. You may very well have some settings issues going on or something else that another member can help you with.
Thanks, I've done all that, I'll figure it out. I've got two little girls so I don't know if 70 will ever be an option up here. Ha ha.
post #1935 of 7056
7.1 aside, I'm guessing most people couldn't tell the difference between DTS core at 1.5 mbps on BD and lossless dts-MA.
post #1936 of 7056
Sounds like an HDMI handshake issue. You figured out the solution on your own. Granted it is not elegant, but it works.
post #1937 of 7056
Which Elite do you have now? I recently sold my old 56TXi. That was, and still is considered one hell of a receiver, but I wanted HDMI. So I had replaced that with the Onkyo 805 because at the time (and for some time after too) it was the only AVR with HDMI and internal decoding on the market. But it could NEVER compare to the Elite 56TXi I had prior. Well, I went out and bought the new Pioneer Elite 03 and really liked it! And the price was sweet too. It sounded so darn aweseome compared to the Onkyo, so much so, that when testing movies out, I would end up watching them as if I had seen them for the first time = the sound was that GREAT! BUT . . . . the new Elite SC-05 had also caught my eye, and I KNEW that if I did not exchange the 03 for it, I would always have it in the back of my mind, so I did exchange the 03 for the 05 and am soooooooo happy I did. But depending on your needs and expenses, any of the new Pioneer Elite AVR's would be perfect for you, as you are already well aquainted with the awesome rich sound they offer. And compared to the Denon's, you get more bells & whistles, and more HDMI ports, at a lower cost with the Pioneer. So why wait
I am currently using the Elite VSX-72TXV and I have been very happy with it right up until I bought the BD-P2550. I felt the same way after auditioning the Elite I have now coming from an older Sony Receiver I had. I'm ready for an upgrade for sure, I too was looking at the Elite 03 for the money it seems you get allot of receiver.... now your making me wonder if I should I just buy the 05 instead and not bother with the 03. I'm going to have to decide if I should sell the 72 I have or just move it into the bedroom. Might put it up sale with my 400 disc dvd changer and my hp 17" laptop and use that money to buy the 05 and the new Asus CS 5111 at bestbuy to store my movies on. Thanks for the glowing review of the new Elite's I was thinking actually about the onkyo 805, now I'm not...
post #1938 of 7056
I think your right. It's probably the HDMI's secure connection. I sometimes get the same problem after I switch away from the Samsung, and come back to it from another source. I won't get audio for the first few seconds. But the audio always eventually shows up. This is through my Philips LCD TV.
post #1939 of 7056
Which remote are you referring too? Are you using the receiver remote, the 2550 remote or a universal remote when you get this problem?
post #1940 of 7056
Exactly. Besides, one should realize that the original master soundtrack is not of infinite resolution either. If a movie was made before the mid 90s, the original master was most probably recorded onto an analog multitrack reel-to-reel deck that had about 20 dB more background noise than even VHS hifi. If the movie was made around the late 90s it has all chances of being recorded onto a Tascam DA-88, which is a popular digital 48 kHz/16 bits multitrack deck. Higher sampling rate and better bit depth on the BD release are then unneeded. Only recent titles may have native digital resolution exceeding what DTS can pass. Judging how DVD-Audio and SACD were failure in the market and how iTunes is slowly killing CDs, I doubt most people need such high resolution sound.
I'm not advocating the use of inferior sounding gear or codecs, but there comes a point of diminishing returns where having "more" may not be readily audible, let alone relevant. Calling the absence of on-board DTS-HD MA decoding a deal breaker for an otherwise very fine player may just be slightly misplaced.
Again, my humble opinion!
post #1941 of 7056
Just a reference point for updating to the latest firmware on my 2550:
Download time was 15 minutes on my solid 6mbps DSL connection.
Verification and update time was about 3 minutes; after which it shut off.
19 minutes after I started, it was done; no problems.
post #1942 of 7056
It doesnt matter which remote. Anyways, i have since fixed the problem. The receiver does not like the 24fps to be on in the bluray. Now it works fine. Wierd, i had it set to pass through. Sux i cant use 24 fps now.
post #1943 of 7056
Originally Posted by nate358 View Post
I have the same feelings about the shortcomings of the 2550. While I think Netflix is great... I use Blockbuster and Pandora is cool, but has something more to be desired from. Now, that DTS-HD MA is not supported, I wouldn't hesitate to take my 2550 back to BB and get the Panasonic 550 if I could "find it" and for $350. With the 550 I'd get DTS-HD MA, a SD Card reader for camera pics, and a lot more supported disk types which might include playing the Bluray Pixar's Short Films Collection, which only my machine won't play.
Ummm? That would be the Panasonic DMP-BD55K . The 550 is the Sony.
post #1944 of 7056
UGH!!!
I bought the 2550 a few days ago along with a Denon AVR-789. I did the latest firmware update via burned CD, all went well. Watched a few movies on Friday, no real issues except while watching Wanted. Audio would drop at a certain point and after trial and error, found that turning the Denon off/on would correct it. BTW, all HDMI all the way through to Panny 42-PH10UK. No other cables used. Motorola Comcast box has been working flawlessly.
Anyway, yesterday I went to watch my lovely new Matrix Blu-ray collection, and the video is dead. Audio works, but no video. I tried switching the HDMI from the TV directly to the Sammy just to see if it was a cable or Denon issue. Nope. I unplugged, replugged, same problem. Denon and Motorola still working perfectly.
This Sammy was one that came with the firmware CD, so manufactured earlier than some out there now. I have heard tell that I should just return the thing for one manufactured in November and all should be well. What do you all think?
Additional Info:
The video problem is not just with Matrix, but everything, it just happened to begin when I inserted that disc yesterday. So no splash screen, nothing, no other DVDs have video. But sound is still there.
post #1945 of 7056
I watched all three Matrixes with firmware 2.1, the firmware just before the Dec 30th version. I had no problems at all. HDMI was connected to the TV, and both optical and analog were attached to the AVR.
I'm not sure what this means. My P2500 also came with a firmware disc - one that I believe added Netflix support. Does that mean I got a "old" unit? It seems to work fine. The only thing apparently old about it is that they didn't have time to flash the firmware and instead put a disc in the box. I guess newer units have this code flashed? That doesn't mean the hardware is different. I haven't heard anything about November units being better than previous units. My P2500 has been perfect so far - except for difficulties in getting it on the network after a firmware update.
post #1946 of 7056
Anyone willing to venture and opinion on the 2550 vs the Panasonic 35? From everything I have read the 2550 does a better job of upconverting but seems to be more finicky handling disks
post #1947 of 7056
I have read the posts about folks being very satisfied with the upconversion of DVD's with the 2500. Unfortunately, I am not able to share in that sentiment. My playback is a bit noisy. The closeups are great, but background and more distant shots seem out of focus. I have tried many different settings, all to no avail. I have sharpness off; have tried the low, medium, high, off noise reductions. I am hoping that the DVD's I have been watching are just crappy, and not the 2500. Stuff I download thru Netflix plays better than the DVD's. I don't know how to explain the problem I am seeing, but when people move, there seems to be somewhat of a stuttering, so that skin tones do not look natural.
I tried setting to 480i, but the machine keeps me on 1080p. I have a 1080p Television, and run HDMI pass through with the Onkyo 606.
Anyone else see this too? Any suggestions?
post #1948 of 7056
I have not had any problems playing BDs, DVDs, or streaming from Netflix, and I bought my 2550 back in August (and subsequently applied the 2.1 and 2.3 updates via USB). So I don't believe that the manufacturing date can be the cause of your problem.
post #1949 of 7056
UGH!!!
Additional Info:
I purchased mine in July and have had zero issues with the playback of any SD or BD thus far. I'm running 100% HDMI to my Onkyo 705 and my FPT-50849 Samsung Plasma and have never had an audio or picture drop. The only issue I have, if you want to call it that, is the HDMI handshake when changing channels on my Plasma. The audio lock takes about 3 seconds before it locks... big deal. However, this is a know issue with the Onkyo and has a FW update I need to perform that corrects that and the dreaded "Gunshot Bomb", which I've never experienced yet.
Considering there aren't very many options in the 2550 to mess with when it comes to audio, I'm more apt to believe that you'll find answers that point to incorrect AVR settings. Not necessarily in all cases, but I would be willing to bet in many.
EDIT: I have to ask this. Did you, after the update, go back into the BDP menu and reset the audio stream to Bitstream (Audiophile)? The player resets to factory settings when you update everytime.
post #1950 of 7056
That annoys me to no end. Samsung fails at NVRAM
