I can't get the USB update to work at all. I get a message that the file is corrupt or something like that. I've tried it 3 times now downloading it from Samsung's website. I even formatted my USB drive and that didn't work.
I even followed these instructions:
When using USB make sure you have the correct file. Unzip the file and copy the .ruf file to the USB stick. Power the player on. If you have the player hooked up via eithernet respond "no" when the player asks if you want to update. If you select "yes" the player will start downloading the file from the Samsung file servers. Now plug in the USB stick and follow the prompts.
You can cancel the download if you selected "yes" in error and the download begins. Just press cancel. Then plug in your USB stick to begin the update process.
But nothing. I guess I will try to download it via the ethernet connection.
Any body else having the same issues?
